Author Topic: Stone guard and front valance date code  (Read 1103 times)
Offline gjz30075
« on: May 14, 2020, 11:27:45 AM »
Hi all...    I was wondering if OEM stone guards and front valance had date codes.  If so, are they stamped? Stenciled?   and where?    And I like If it matters, this is for a SJ built 66.
Greg Z
Re: Stone guard and front valance date code
« Reply #1 on: May 14, 2020, 12:55:14 PM »
Both date stamped, format Day/Month/Plant-Shift (i.e. 1 23 D2).  Any stencils would indicate a Ford or repro replacement part.
Offline gjz30075
« Reply #2 on: May 14, 2020, 01:05:06 PM »
Thanks Charles!
Greg Z
« Reply #3 on: May 14, 2020, 05:03:49 PM »
To illustrate with a couple of extra date code locations from related parts
Bumper
Lower valance
Stone guard/Upper valance
Lower grill bar. Made up of two sheet metal panels so in this case - two dates
Offline gjz30075
« Reply #4 on: May 14, 2020, 08:06:53 PM »
Perfect!  Thanks Jeff!
Greg Z
Offline ChrisV289
« Reply #5 on: May 14, 2020, 08:48:21 PM »
Jeff,
Would this be a NOS stone guard from 1979?
2009 V6 Mustang Coupe
« Reply #6 on: May 14, 2020, 09:50:46 PM »
Jeff,
Ford replacement part, date format wrong.
« Reply #7 on: May 15, 2020, 12:25:17 AM »
Jeff,
Yes that is the pattern found on many of the mid to late 70's NOS sheet metal.
Offline gjz30075
« Reply #8 on: June 01, 2020, 01:35:47 PM »
If you don't mind, I'd like to bring this up again.    Pictured is a 65/66 lower front valance but the date looks its from 67.    Possibly
an early service replacement?
Greg Z
« Reply #9 on: June 01, 2020, 02:23:58 PM »
Not sure why you would think its from 67. As its decoded in the date coding article in the library and in other threads the year code is not included in the stamping code pattern. The "7" is the month. Pattern Month - day of month - stamping plant code(not used on all years and sheet metal pieces) - shift
Offline gjz30075
« Reply #10 on: June 01, 2020, 03:14:55 PM »
Ah,  I'm forgetting.   Thanks!
Greg Z
