Author Topic: 66 I6 coupe Speedo Cable?  (Read 1194 times)
Offline hughnews1
« on: May 14, 2020, 10:43:17 AM »
going to NPD  for new speedomeotor cable   on the C4  where does the cable go ?  any pics  thanks HUGH
« Last Edit: May 25, 2020, 07:34:16 PM by J_Speegle »
hugh  schnacky
Offline ChrisV289
Re: 66 I6 coupe
« Reply #1 on: May 14, 2020, 12:24:16 PM »
There should be a hole below the steering column for it to run.
2009 V6 Mustang Coupe
Re: 66 I6 coupe
« Reply #2 on: May 14, 2020, 01:03:24 PM »
Did you look in the unrestored area?
http://www.concoursmustang.com/forum/index.php?board=63.0
I see a T code from 65, not sure if they are the same.  The pictures of the engine compartment are nice:
http://www.concoursmustang.com/forum/index.php?topic=16275.0
Re: 66 I6 coupe
« Reply #3 on: May 14, 2020, 02:00:56 PM »
Speedometer cable routings are shown in the 64-65 Mustang Chassis Assembly Manual, pg 24, 66 is very similar.
I recommend you get a set of assembly manuls for your car.
Offline hughnews1
Re: 66 I6 coupe
« Reply #4 on: May 16, 2020, 07:59:28 PM »
i went to NPD  today  .. the counter was closed     they sold me elec  manual  ..
hugh  schnacky
Offline hughnews1
Re: 66 I6 coupe Speedo Cable?
« Reply #5 on: June 08, 2020, 07:50:52 AM »
i need the c4 end    what colors ..   for I^6
hugh  schnacky
« Reply #6 on: June 08, 2020, 01:07:57 PM »
Look in the lounge for the 65-72 Ford Car Parts files in Adobe .pdf format.
« Reply #7 on: June 08, 2020, 06:57:35 PM »
Don't recall the routing or retaining hardware to be different between V8 and I6 that year.
Beyond the firewall details the cable travels down the drivers side of the floor and is attached to the transmission cross member as shown in the picture below before it attaches to the trans
If your referring to the speedo gear use the resource Jim posted and you'll need your rearend gear ratio. With those two the part number and color should be there
Offline hughnews1
« Reply #8 on: June 17, 2020, 01:11:00 PM »
THIS  might be the tag  off C4   WCY -R  283  5EA 909
hugh  schnacky
Offline hughnews1
« Reply #9 on: June 17, 2020, 01:25:24 PM »
according to the book   its   3.25
hugh  schnacky
« Reply #10 on: June 17, 2020, 03:07:18 PM »
Now I figured out what you are looking for, your PM was confusing.
Need:
- build date
- engine type
- transmission type
- rear axle ratio
- tire size
Offline hughnews1
« Reply #11 on: June 17, 2020, 07:40:02 PM »
no build date   200  engine  c4    3.25       tire size     60  x14"
hugh  schnacky
« Reply #12 on: June 18, 2020, 12:09:58 AM »
Hugh,
Axle ratio 3.25:1 is not listed for a 66 Mustangs with a C4. However, 3.20:1 is. The tire size listed is what was delivered in 1966. Ratio 2.83:1 is the only other ratio listed for your combinations. The color of the gear should be Gold, and have 18 teeth.
Offline hughnews1
« Reply #13 on: July 04, 2020, 12:24:38 PM »
thnaks    a friend  will coming over to installed it    6 cyl guy
hugh  schnacky
