Author Topic: 65 Distributor Dates ?  (Read 985 times)
« on: May 13, 2020, 04:26:56 PM »
Is there a usual or accepted date range for the C5GF-12127-A assembly line installed  ' A ' code distributor ?  MustangTek's web page has an photo example with a 4MC date stamp.   1964, December and third week for a production date?   Just in time for the GT introduction ?  I recently heard of another C5GF-A distributor with a date stamp 4JC.  Did this C5GF-A model carry thru all of 65 production ?  Thanks, Brian
Re: 65 Distributor Dates ?
« Reply #1 on: May 13, 2020, 05:21:50 PM »
Can't answer how long C5GF-A's were used (without a little more time in the data) in production but and A code dist has little to do with the release or first build of the GT since most A codes were not ordered as GT's  and they predated the GT option availability. Sure one of the regular 65-66 members will have an idea of the application range of the specific dist
« Reply #2 on: May 13, 2020, 06:19:49 PM »
Thanks - misread your meaning
« Reply #3 on: May 13, 2020, 07:18:44 PM »
Mannell, Appendix D, pg D-3, shows only one distributor for all "A" code engines in 1965 - C5GF-12127-A.
« Reply #4 on: May 15, 2020, 04:57:49 PM »
Green primary wire eyelet connection is a common feature or did it change depending on the car line ?
Offline ChrisV289
« Reply #5 on: May 15, 2020, 10:02:11 PM »
Looking at Mikes unrestored cars, one is yellow and one appears white
2009 V6 Mustang Coupe
« Reply #6 on: May 15, 2020, 10:36:40 PM »
At least in later cars the color relates to the length and in turn the application for the wire
Just one of a couple discussions for later cars
http://www.concoursmustang.com/forum/index.php?topic=19892.msg125729#msg125729
« Last Edit: May 15, 2020, 10:55:30 PM by J_Speegle »
« Reply #7 on: May 16, 2020, 08:09:41 PM »
Well at 20" end to end it seems a bit long ?  Yes I measured it twice.  Brian
« Reply #8 on: May 16, 2020, 10:20:35 PM »
Don't have an early 65-6 small block dist with an original lead sitting around to measure and compare. Maybe someone else will
Offline Hipo giddyup
« Reply #9 on: May 17, 2020, 02:27:55 PM »
I have two readily available distributor leads handy. One is from a 65’ the other has the elbow lead and I think is from my 67’ spare distributor. They both measure about 13 1/2” from lead to lead. The 65’ measures appr. 8 1/2” from the external surface of the distributor to the leads yellow eyelet. Not sure if this can help. I have another original distributor but need to go to my other garage to take a pic.
