Author Topic: Power Steeing Hose Cover Sleeve  (Read 620 times)
Offline 1970 Snake
« on: May 10, 2020, 04:44:51 PM »
Can anyone advise if the soft foam like power steering hose covers being remanufactured and available? If not what is being done to replicate these pieces?
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Re: Power Steeing Hose Cover Sleeve
« Reply #1 on: May 10, 2020, 04:54:42 PM »
Yes I worked with dan carpenter on this foam since it always goes bad and its used on 69-70 cars.
Offline 1970 Snake
« Reply #2 on: May 10, 2020, 05:55:47 PM »
So are you saying it is now available from Daniel Carpenter? If so is there a part number and who sells it?
« Last Edit: May 10, 2020, 06:18:06 PM by 1970 Snake »
« Reply #3 on: May 10, 2020, 07:24:24 PM »
If u cant find it I got some extra.
Offline 1970 Snake
« Reply #4 on: May 10, 2020, 07:38:58 PM »
Much appreciated, thanks Ed, will see if I can find it.
Offline Mike_B_SVT
« Reply #5 on: May 11, 2020, 02:26:42 PM »
Check NPD.  I think that's where I got mine a few months ago.
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
Offline 1970 Snake
« Reply #6 on: May 11, 2020, 02:35:25 PM »
Thanks Mike yes they have it, need to use their search engine to find it though
« Reply #7 on: May 11, 2020, 05:14:02 PM »
Is the reproduction stuff close or just like the original?
If so glad they carry it now - use to have to buy it from the GM guys/sources. Not that that was a terrible thing :)  Same thing we had to do int he early 90's with the white Thermactor pump fans  ::)
Offline 1970 Snake
« Reply #8 on: May 11, 2020, 05:51:37 PM »
They only sell it in 20" long pieces, I am not sure I have all my original hose covering or where it goes, can you advise where the covering goes on the hoses possibly with pictures, thanks
