I have an early 65 (feb build date). The water pump is cast iron and the only marking on it is "PH-288" Everything I read indicates early 65's had aluminum water pumps. Is this pump correct? See Pic. Are these pumps rebuildable and if so what is involved? difficulty?
If this water pump is incorrect would that mean that the timing chain cover is wrong also?
I haven't seen a cast iron after market version to the assemblyline aluminum pump in quite a few years. Your pump is a replacement.
