Author Topic: WTB: 65 driver side standard 289 valve/rocker cover  (Read 868 times)
« on: May 07, 2020, 11:54:30 AM »
Looking for a LH side valve cover for a '65 289.  The '65 version does not have notches for smog tubes along the bottom edge.  Can trade for one if notches?
Will buy a pair if needed.  Prefer non-rusty/non-damaged.
Re: WTB: 65 driver side standard 289 valve/rocker cover
« Reply #1 on: May 07, 2020, 03:58:18 PM »
Charles I have a pair here in, stay at home, San Diego.  Both do have some rust, passenger side couple small dents at the rear and the drivers side is dent free.  Never seen the smog tubes ?  Can send pictures.  Brian
« Reply #2 on: May 08, 2020, 11:01:36 AM »
After a closer look this AM the covers I have are not suitable for your needs.  Brian
« Reply #3 on: May 08, 2020, 11:04:54 AM »
Thanks for checking.
« Reply #4 on: May 08, 2020, 02:43:07 PM »
You even learn things in the WTB section!
I had to look up 'T/E notches' and found it in Mannel's book on page 6F2-b.
How about that!
Offline ChrisV289
« Reply #5 on: May 08, 2020, 03:26:43 PM »
I looked as well Charles. I have a pair I am going to be using as masks when I repaint the engine but the passenger side is 65 and the driver is 66
2009 V6 Mustang Coupe
« Reply #6 on: May 08, 2020, 04:00:08 PM »
We have the same then, I've also been using a pair like that for masks, but now need a pair of 65's!
Offline Hipo giddyup
« Reply #7 on: May 09, 2020, 12:31:57 PM »
Hey Charles. I was looking  around and found a pair of non-notched 65 valve covers. However, these were the over-the-counter chromed versions. Not sure if that would be any use to you? I imagine you would be stripping the chrome to make it work?
Offline OldGuy
« Reply #8 on: May 09, 2020, 02:11:37 PM »
Charles, I've got exactly what you asked for. PM for details.
Frank
Offline lancelot66
VR/
-Lance
SJ Build Date: 1/6
Many Original Options
« Reply #10 on: May 22, 2020, 02:37:24 PM »
Thanks for all the replies.  Found what was needed.
