Join us on Facebook: Search for 'ConcoursMustang' Private group!https://www.facebook.com/groups/concoursmustang/Indiana SAAC Fall Classic , French Lick, IN Oct 11-12http://www.insaac.org/SAAC National-Sanctioned Concours Event
Richard, Thanks a million. That is exactly what I was talking about. In your third picture, is that the short end of the spring that can be seen sticking out by the ear on the detent? I appreciate you taking time to get these pictures and post them.Tom Gilliamtom@jtgil.com
How do you get the handle off? Do you drill out the pin?
Hallo Tom,i rebuild mine two years ago and had the same problem… the short end of the spring goes to the H-detent, the long one towards the handle. It will “push” the detent down so it engages with the saw-tooth of the handle when pulling out. You can easily check the function without cables and Installation.enno
Good Day bullitt68,I believe the unit I am working on was the original assembly line handle assembly.Tom Gilliam
Thanks for posting ENNO. Are all your parts original?
Yes, it should be. It has the "FoMoCo" Logo stamped on the side of the handle.
