Author Topic: Check Valve Brake Booster  (Read 501 times)
Offline vorrath
« on: April 30, 2020, 04:44:03 PM »
What is the correct check valve for 69 Bendix Brake Booster.?  Is it the DOAZ-2365-A?
Re: Check Valve Brake Booster
« Reply #1 on: April 30, 2020, 07:03:45 PM »
First welcome to the site. Hope you find the information and support you need for your restoration
With that part number likely no but it may look similar ( don't have one in front of me).
Appears in pictures to have the sharp outer edges with the sunken center with one attachment port originally
One example - not sure if the center markers/suppliers marks are correct on this one
Molded in white but of course painted semi-glass black with the rest of the mater cylinder and booster assembly before installation
« Reply #2 on: April 30, 2020, 08:30:02 PM »
Here is one on ebay. https://www.ebay.com/itm/1969-1970-1971-Mustang-Mach1-Boss-Shelby-Cougar-BENDIX-BRAKE-BOOSTER-CHECK-VALVE/401933216813 . the assemblyine check valve had the diamond design detail in the middle. Painted black with the booster as Jeff said.
