Author Topic: What is a 4 wire turn signal indicator relay?  (Read 511 times)
Offline kkupec02
« on: April 24, 2020, 01:44:01 PM »
I have electrical issues that I am trying to figure out. I have confusion however. My problem is very similar to what is in picture 1 of my 1967 cougar, mustang, fairlane, falcon, mercury shop manual. That manual mentions fix could be 4 wire turn signal indicator relay. According to the wiring diagrams, I haven't gotten behind dash panel yet, there is a turn signal flasher and an emergency flasher. Picture 2 shows what is being sold for both applications today. They are not 4 wire though unless you add them together. Further confusion are pictures 3 and 4 showing original EBay flashers which have more than 2 wires, but not 4. What is service manual referring to regarding 4 wire turn signal indicator relay?
1967 GT500 Built 1/26/67 #817
1967 Corvette Roadster
Re: What is a 4 wire turn signal indicator relay?
« Reply #1 on: April 24, 2020, 02:04:18 PM »
Keep in mind that a relay is not a flasher, and vice versa.
Regular old 67-68 Mustangs use (1) a 2-wire flasher for turn signals, (2) a separate 2-wire flasher for emergency flashers, but (3) no relay.
The only relays used on regular Mustangs are for the optional seat belt warning light (which is a "time out" relay), the optional low fuel warning light, and the optional tilt-away steering column.
I don't have a wiring diagram specific to the Shelby or the Cougar though.
Offline 196667Bob
« Reply #2 on: April 24, 2020, 02:21:45 PM »
In looking at the Shop Manual, the statements noting "4-Wire Relay"  appear to be only for the Cougars, which used a 4 Wire Relay for the Sequential Turn Signals. So, unless you have a Cougar, ignore this. The only Relays used on 67 Mustangs were as John noted above.
Bob
MCA 04909
« Reply #3 on: April 24, 2020, 02:46:08 PM »
Regular old 67-68 Mustangs use (1) a 2-wire flasher for turn signals, (2) a separate 2-wire flasher for emergency flashers, -
Sligtly off topic, flashers are also identified as being for "2 lamp" for turn signals and "4 lamp" for emergency flashers.  I don't remember the symptoms or specifics, but they normally don't interchange.
Offline kkupec02
« Reply #4 on: April 24, 2020, 03:15:08 PM »
Thanks all. I'm still working on my wiring problem.
« Reply #5 on: April 24, 2020, 03:28:54 PM »
More bulbs take more current, more current will heat up the flasher bimetallic element faster. So a 2 bulb flasher in a 4 bulb circuit will have a mouth shorter (probably by 4 times) on dwell time.
