Author Topic: 65 66 Fastback measurement needed  (Read 908 times)
Offline hertz350
« on: April 21, 2020, 03:08:35 PM »
I am looking for a measurement to locate the  trap door hinge mount onto the inner wheel well. I am looking for the distance from the metal piece the trap door rests against to the front edge of the trap door hinge bracket at the wheel well. Thanks.
Re: 65 66 Fastback measurement needed
« Reply #1 on: April 22, 2020, 02:50:23 PM »
Can't help with that measurement.  For a reference;  Measuring from the other end it is 1.5"  between the bracket top and the header lower edge.  Brian
« Reply #2 on: April 22, 2020, 05:10:25 PM »
I took some time out of my busy schedule (others can't) and removed some stuff that was in the way (spare, mat, liner) to take a couple of pictures.
The measurements I made were from a couple of fixed points on that inner fender well piece and the trunk floor.
From the trunk floor up to the center of both prop mounting hole: 3 inches.
From the gas tank sender wire hole center, forward to the front prop hole: 1 inch. The rear hole appears to be 1 1/2 inches to the rear of the front.
Any closer measurements would require a significant inducement in the form of JD No. 7.
Oh, the last was dinner on January 25, 2020, a "late" Christmas dinner with friends, before being cracked, dipped in garlic butter and roasted in the oven for 10 minutes. Recipe supplied on demand.
Offline hertz350
« Reply #3 on: April 22, 2020, 06:29:00 PM »
Thank you so much!. I appreciate the time and effort it took to get this information. It solved my problem. Maybe I will see you at a SAAC convention and I  will buy you JD-7.   Nice crabs We don't get those much here in eastern Washington.
Part Cronin.
« Reply #4 on: April 23, 2020, 01:31:11 AM »
Pics with the bracket removed...
« Reply #5 on: April 23, 2020, 10:36:52 AM »
Many of the early service replacement trunk floor panels had location dimples in the metal for the purpose of installing the rev nuts.
« Reply #6 on: April 23, 2020, 05:15:08 PM »
Original floors also came with the locating dimples also and can be found on coupes and convertibles also. Convertible upper left - Coupe lower right
Guess we could have just supplied the distance for the forward most one to help you position the lower arm mounting location
Offline hertz350
« Reply #7 on: April 23, 2020, 07:10:57 PM »
Thanks everyone. I have what I need now to mount the prop rod in the right place. This is truly a great site. Thanks again.
