Author Topic: fuel tank drain plug  (Read 726 times)
Offline fmr187
« on: April 21, 2020, 12:45:45 PM »
When did Ford add the drain plug to the fuel tanks? My 65, built in Feb, does not have a drain plug. Researching this what I find is everything mentioning the drain plug. Was there a change over during the year?
65 Convertible born in Dearborn on Feb 10
Re: fuel tank drain plug
« Reply #1 on: April 21, 2020, 01:23:41 PM »
Drain plugs were used 65-68 and it was either in 69 or 70 when tanks without them started being used in production.
If your 65 doesn't have a drain plug, it's a replacement.  Ford serviced them like that too, even though they didn't match what was installed on the assembly line.
« Reply #2 on: April 21, 2020, 03:24:30 PM »
+1 . Early 69 production had drain plugs the transition to without was later 69 up .
Offline fmr187
« Reply #3 on: April 21, 2020, 06:13:12 PM »
My tank has the following part number stenciled on it. C5ZZ-9002-D. Is this a Ford replacement number?
« Reply #4 on: April 21, 2020, 06:16:48 PM »
The fact that it has a stenciled number on it suggests that it was replaced with a service replacement unit
On later versions a stenciled date can be found also during some eras
« Reply #5 on: April 21, 2020, 08:34:19 PM »
Keep in mind any part number prefix with a trailing 'Z' is a replacement part number, not an engineering part number.  There wouldn't have been any 'ZZ' markings/tags from the assembly plant on a Mustang.
