Author Topic: Looking for a realitively unmolested GT350 or dearborn Mustang owner to help  (Read 859 times)
Offline Coralsnake
Im looking for some detail info under the car on a 69 4spd gt350 or Detroit mustang
Looking for info on bolts holding block plate to bell housing and type of cotter key holding clutch adjuster rod under car
Checked for you and only have pictures of the lower inspection/block plate to bellhousing bolts for automatic applications. Since the bell housing would have been installed at the engine plant on manuals it shouldn't matter where the car was built for that detail.
No help with the lower clutch rod cotter key but it may be shared with the Boss 302's built at Dearborn to widen the possible search. Maybe even all ( 428CJ) at that plant also.
Just what I've got at the moment
Offline Coralsnake
Thank you Sir
I hope you dont mind if I hang out here until the SAAC forum resolves its ongoing issues with trolls and @$$ clowns?
Thank you Sir
As long as everyone leaves their floppy big shoes at the front door all is good ::)
