Author Topic: Some measurements!  (Read 689 times)
Offline Armond
  • Silver Level Subscriber
    • D'Agostini Restorations.com
Some measurements!
« on: April 07, 2020, 04:54:16 PM »
I am hoping one of you out there can get me a few measurements.  The core support on this car was replaced back in the early days, Brazed on.  Really poorly done and holes for the A/C and oil cooler butchered.  The new NOS core supports do not come with the Hood stop brackets installed, really dumb, well the way they brazed these back on I don't trust the measurements.  So I am needing the following, from the bottom of the front frame rail to the top of the bracket and from the oval hole to the center hole of the bracket. The oval hole to each side, the pics hopefully you can see what I need.  I just don't have a 67/68 sitting here to get he measurement. Thank you for any help!
MCA#31064
Offline Keith Stem
Re: Some measurements!
« Reply #1 on: April 07, 2020, 05:37:27 PM »
Armond
My 68 CJ Measurement are 17 1/2 from the center of the hood latch rod bolt to the center of the hood adjuster bolt, and from the bottom of the frame rail to the top of the bracket is 18 5/8.
Keith Stem
Offline Armond
« Reply #2 on: April 07, 2020, 07:48:03 PM »
Thank you Keith!
MCA#31064
« Reply #3 on: April 07, 2020, 07:55:18 PM »
My car is 17-1/2” (same) and 18-3/8” (close)
Offline Armond
« Reply #4 on: April 07, 2020, 10:47:51 PM »
Maybe I will split the difference!  Thanks!
MCA#31064
Offline Keith Stem
« Reply #5 on: April 08, 2020, 10:32:11 AM »
Armond
I made a measurement from a different direction. The top of the hood adjuster brackets are 1 5/8 below the center line of the center bolt of the radiator support frame. This might be a way to cross check, or maybe just muddle up the whole measurement process.
Keith
Offline Armond
« Reply #6 on: April 09, 2020, 12:07:24 AM »
they are spot welded in place, but thanks I will check that measurement tomorrow!
MCA#31064
