Author Topic: Brake cables  (Read 1230 times)
Offline Armond
  • Silver Level Subscriber
    • D'Agostini Restorations.com
Brake cables
« on: April 04, 2020, 07:27:52 PM »
Are the 68 Convert rear brake cables the same as the 67 cables you can get from inline? Equal length?  Thanks!
MCA#31064
1967 eight barrel
  • Guest
Re: Brake cables
« Reply #1 on: April 05, 2020, 01:21:17 AM »
1968 has a long and a short cable. 1967 has two equal length cables.
Offline Armond
Re: Brake cables
« Reply #2 on: April 05, 2020, 02:32:05 AM »
This 68 convert shelby I am working on has two short cables and look the same as the 67 style.  So did the all 68 converts have short?  These need to be replaced and I am wondering if anyone has used the 67's.
MCA#31064
1967 eight barrel
  • Guest
Re: Brake cables
« Reply #3 on: April 05, 2020, 06:18:41 AM »
Regardless of model each respective year has the same cables. 1967 was identical length, 68 two different.
Offline Coralsnake
Re: Brake cables
« Reply #4 on: April 05, 2020, 08:35:36 AM »
Armond all 1968 Shelbys used the same type of ebrake cable. You should have one side that is short and one longer. You will also likely need to change the color of the fittings. I have also found end balls to be oversized on some reproductions.
Offline Armond
Re: Brake cables
« Reply #5 on: April 05, 2020, 03:14:36 PM »
I would rather not replace the cables but the rubber is all cracked, so when I was researching to find the best replacement cables out there available, I found the long/short cables listed as correct when this car has the two equal cables. Here are some pictures I have taken.  Thank you for your input!
MCA#31064
Re: Brake cables
« Reply #6 on: April 05, 2020, 04:00:18 PM »
Armond -- there is a thread out there about how to replace those cracked rubber sleeves.
Bullitt68 was the last user who tried this in a recent post.
I used very fine glass ball (not that HF broken up glass) media on my cables and they look very good. Better details than the repops.
I'll post a pic later (perhaps in my build thread).
Offline Armond
Re: Brake cables
« Reply #7 on: April 05, 2020, 04:20:51 PM »
Thank you for the tip, I will go see if I can find it!!
MCA#31064
Re: Brake cables
« Reply #8 on: April 05, 2020, 05:29:48 PM »
Found it:
http://www.concoursmustang.com/forum/index.php?topic=11803.msg111073#msg111073
The size of the latex required is discussed in the thread earlier ...
Re: Brake cables
« Reply #9 on: April 05, 2020, 07:19:42 PM »
Here is a link to how they look cleaned.
http://www.concoursmustang.com/forum/index.php?topic=16775.msg139229#msg139229
I need to clean my rug, however.
1967 eight barrel
  • Guest
Re: Brake cables
« Reply #10 on: April 05, 2020, 07:25:14 PM »
If you elect to restore the cables the rubber seals are available from AMK.
Re: Brake cables
« Reply #11 on: April 05, 2020, 07:28:46 PM »
Yeah, the big ones. The small ones, not that I've found.
I have one off and want to cast it out of black silicone so it can stretch over the ball.
1967 eight barrel
  • Guest
Re: Brake cables
« Reply #12 on: April 05, 2020, 07:35:15 PM »
The fine glass bead works well on non-rust-belt cars usually. Getting it all out of the cable not so much. Fry's Electronics also offers many sizes of shrink tube which is another option for the cracked rubber insulator.
Offline Armond
Re: Brake cables
« Reply #13 on: April 05, 2020, 08:03:25 PM »
Thank you! I will look into doing this.  I appreciate the help!
MCA#31064
Offline bullitt68
Re: Brake cables
« Reply #14 on: April 08, 2020, 04:00:16 AM »
Hi Armond I just restored my cables as per BossBills advice and they turned out pretty good I think. The Latex tube works great. Good luck! They were in pretty rough shape to begin with
Mike
