Author Topic: Carburetor Studs  (Read 603 times)
Offline ChrisV289
Carburetor Studs
« on: March 30, 2020, 10:45:39 PM »
What is the correct carburetor stud length for a 66 Hertz automatic (autolite 4100)?
2009 V6 Mustang Coupe
Re: Carburetor Studs
« Reply #1 on: March 31, 2020, 12:25:07 AM »
Same as the 4 speed.
Offline ChrisV289
« Reply #2 on: March 31, 2020, 12:30:02 AM »
Does it use the same as the standard intake and carb setup? NPD and Virginia Mustang both carry various lengths
« Reply #3 on: March 31, 2020, 01:13:39 AM »
I am not as familiar with regular Mustangs as I am with Shelby's. I believe the regular Mustang cast iron intake used a spacer which the the Shelby did not. I have always gotten the studs when I needed them from AMK . I don't remember how they were listed but it must have been easy to find as I don't recall a issue in finding them. Maybe a 65-70 GT350 intake stud kit or something like that .  Once the stud is threaded into the intake the stud stands approximately 1 inch tall .
« Reply #4 on: March 31, 2020, 06:29:00 PM »
Sorry don't have any Mustang ones out and not a single cast iron intake to remove one for you :(   Hopefully someone else will to help you out
Offline 196667Bob
« Reply #5 on: March 31, 2020, 09:46:34 PM »
Chris : If the Hertz uses a 1" spacer, like the other 1966 A and K codes, the correct studs are as follows :
Part # 88471-S ; overall length = 2-1/2" ; 1/2" of 5/16-18 thread ; 5/8" of 5/16-24 thread. Picture attached.
None of the Reproductions I have seen are technically correct, as the lengths of thread are incorrect. However, once installed, who will know.
Hope this helps.
MCA 04909
« Reply #6 on: March 31, 2020, 10:18:02 PM »
Hope this helps.
Hertz or other 66 auto GT350 does not use a spacer as I already mentioned in Reply # 3 .
