Author Topic: 68 lower windshild trim spacers  (Read 5421 times)
Re: 68 lower windshild trim spacers
« Reply #15 on: September 16, 2012, 10:58:15 PM »
The ones that I have are from San Jose cars that just had one on a side. May be Jeff can shed more light on the SJ cars. It may be a plant thing.
Marty
« Reply #16 on: September 17, 2012, 11:48:27 PM »
Marty
Haven't studied this particular detail though its more than likely a worker thing - of course one worker would share short cuts and practices often with another at the same plant. Just a thought/possibility
« Reply #17 on: September 18, 2012, 10:51:23 PM »
According to the MPC's (Ford and Mercury) the part number is C7ZZ-6503150-A and the call out is for four of them to be installed 1967-68 Mustang and Cougar. They obviously fit into the cut outs on the lower windshield moulding. I found them on 1967 Dearborn and 1968 San Jose Cougars. Never found one in the end position, only the location in the picture which roughly is over the fender and cowl joint. They are visible when installed, barely.
There are 3 different spacers listed for 1969/70.
C9ZZ-6503150-A (MPC) or C9ZB-6503150-F (Body Assy Manual) 1 installed center of cowl, and it is 2 inches wide.
C9ZZ-6503150-B (MPC) or C9ZB-6503150-H (Body Assy Manual) 2 installed per car, one over each fender, and it is 3/4 inches wide.
C9ZZ-6503150-C (MPC) or C9ZB-6503150-G (Body Assy Manual) 4 installed per car, over the cowl and it is 3/4 inches wide.
This shows the differences of them. The 2 inch wide version is the same as the cowl one but 2 inches wide.
« Reply #18 on: September 18, 2012, 11:48:02 PM »
Nice Scott
« Reply #19 on: September 19, 2012, 12:49:31 AM »
And as Danny found, those cut-outs are not present on 65-66 cars... but the NOS service replacement lower molding is almost always the later design, yet carries a C5ZZ number.  Typical Ford superseding of part numbers, one size fits all.
