There is almost no data on the Shelby rear axle since the whole assembly was listed as part of the add/delete SVO sheets. Other than tribal knowledge, of course.
Since my rear brake cylinders were replacements I looked for either an MPC list of what it had originally or any other document on the cylinder size. Found nothing specific, just inferences. I then looked for the most likely candidate which is the 'B' station wagon with 10x2 1/2 brakes. That matched the Blue dot C3OZ-A.
JD showed a listing on his for sale site (
http://www.allclassicmustang.com/1967MustangPartsNew.html) where he had a pair of 65/67 Shelby rear cylinders noted as having
Blue paints dots. This decodes as follows:
Drum Dia...........Engine..........Cyl Dia....Color.........Part No.
10x1 3/4...........289 4V-GT......7/8........Green........C6OZ 2261/62-A
10x1 3/4...........390 4V...........13/16.....White........C7ZZ 2261/62-A.....CB Brown
10x2 1/2...........Sta Wgn.........15/16.....Blue*........C3OZ 2261/62-A
*Blue is also noted as a 6 cyl cylinder of size 27/32.
So while CB Browns reproduction is identical in appearance, it's the wrong cylinder size for a Shelby. I suppose I could either let it be or bore them out and put in differnt pistons.
Is there any other data on this?
