Author Topic: Ignition Switch  (Read 605 times)
Offline rrenz
Ignition Switch
« on: March 23, 2020, 09:33:09 PM »
Funny enough my father and I have both been fighting with faulty ignition switches. naturally theyre of the reproduction type. Mine is about a year or so old and is randomly not starting and shutting off randomly. I replaced part of the harness with a new pigtail and soldered on new connections when the last unit went in. I'm fairly certain I don't have a connection issue Same issue on my fathers 64 galaxie. He's on switch number 3 I think. Ive messed with connections and cleaned what I could. I purchased a NOS switch and was curious if I should do anything to the switch before installing it as far as cleaning or checking resistance etc...
Ryan
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
Offline rocket289k
Re: Ignition Switch
« Reply #1 on: March 24, 2020, 12:33:08 PM »
From personal experience I've had a couple of reproduction ignition switches fail and exhibit the same symptoms that you described.  As a result, I bought a NOS switch and have had zero issues since.  I didn't do any pre-checks whatsoever - I just installed it.
Regards,
Ron
« Last Edit: March 24, 2020, 12:41:09 PM by rocket289k »
Re: Ignition Switch
« Reply #2 on: March 24, 2020, 02:41:29 PM »
+1, plug-n-play!  :)
Re: Ignition Switch
« Reply #3 on: March 24, 2020, 03:11:01 PM »
reproduction = plug and pray...pray that it works
Offline rrenz
Re: Ignition Switch
« Reply #4 on: March 24, 2020, 08:14:20 PM »
sounds about right. thanks everyone
Ryan
C-4 Automatic
Build Date Jan 21st
