Author Topic: small block oil pan  (Read 2500 times)
Offline T Lea
small block oil pan
« on: December 22, 2010, 12:07:59 PM »
Found out my oil pan has a .030 oversized drain plug installed. Does anyone make an oversize that looks OEM? How are the repro pans (as far as correctness)? Thanks
Offline gtamustang
  • CPM
Re: small block oil pan
« Reply #1 on: December 22, 2010, 07:42:56 PM »
I found the same thing on the 68 coupe that I am working on...5/8-inch pan plug!! From What I have seen, the repros do not have the FoMoCo logo stamped into the pan.
Regards,
Pete Morgan
Offline T Lea
« Reply #2 on: December 23, 2010, 12:50:52 AM »
Thanks Pete. Other than the FoMoCo can you tell a repro pan from an original?
Offline Keithc8
« Reply #3 on: December 24, 2010, 02:18:31 AM »
 Tim I can not remember but inside the oil pan is there any kind of extra metal where the plug goes into the oil pan. I have seen where the pans almost had something like a nut inside them. You could weld a littte extra metal piece inside the oil pan and then drill and tap for the original style drain plug. Let me know if we can help you with that.
Good luck, Keith
Offline gtamustang
  • CPM
« Reply #4 on: December 27, 2010, 02:48:30 PM »
Tim,
I see where VA Classic Mustang now sells a repro small block pan with the FoMoCo stamp. They claim it to be exact. You might want to give Brant a call and get a "test" try.
Regards,
Pete Morgan
Offline T Lea
« Reply #5 on: December 27, 2010, 08:23:11 PM »
Pete, where did you see that? I can't find it on their website and I called and girl that answered says she has nothing that matches that description. Are you looking at the big block one?
Offline Sunlitgold68
« Reply #6 on: December 27, 2010, 10:29:10 PM »
Tim, I can get you an original if you want one. might not be perfect but will be original.
8T01C204XXX
Built May 14th, 1968
Offline T Lea
« Reply #7 on: December 28, 2010, 07:58:40 AM »
Thanks John. I think I will take Keith's suggestion and weld a nut inside. Sounds like a good fix.
Offline gtamustang
  • CPM
« Reply #8 on: December 29, 2010, 11:32:21 AM »
Ti,
My error...too much burbon at the time. You are correct that the FoMoCo repro pan is for the big blocks, not the small blocks. Take the weldiing a bolt route to fix your pan.
Regards,
Pete Morgan
