Author Topic: Adding Disc Brakes  (Read 552 times)
Offline ChrisV289
Adding Disc Brakes
« on: March 19, 2020, 07:04:31 PM »
So I want to add the factory disc brake setup to one of my cars. I assume the two raised areas are where I would drill the holes for the proportioning valve? Also what size hole are they supposed to be?
2009 V6 Mustang Coupe
Re: Adding Disc Brakes
« Reply #1 on: March 19, 2020, 07:13:33 PM »
Look at the Chassis Assembly Manual. The mounting hardware part number is called out. Then look at the Mustang Hardware Spreadsheet 64-66 by part number. An appropriate size clearance drill can then be determined.
« Reply #2 on: March 20, 2020, 01:15:09 AM »
From a couple of 66 examples
They are at an angle from one another
Bottom left taken from the wheel well side - Top right from the engine compartment size
Don't have the size of each hole's measurement handy
« Reply #3 on: March 21, 2020, 08:44:23 PM »
I have factory DB on my 65 and both holes are the same size and just a bit over the thread size of the bolt (0.310).
