Author Topic: 1970 CJ Distributor Markings  (Read 619 times)
Offline 1970 Snake
« on: March 09, 2020, 01:00:17 AM »
I am in the process of rebuilding/retoring my stock Ford distributor and am finding the casting has a dark redish/brown spray in one location on the outside of the housing and its finish seem quite permanent, not sure why it would have been don't after it left the factory. Did Ford put any spray type lube, coating, paint marking on the outside of the distributor housing? See attached photo
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Re: 1970 CJ Distributor Markings
« Reply #1 on: March 09, 2020, 03:12:37 AM »
I for one have not seen a mark exactly like that from the factory. Most likely something that has happened some time in the 50 years /half a century since it left the factory. ;)
Offline 1970 Snake
« Reply #2 on: March 09, 2020, 05:21:09 AM »
How and/or what was used to lubricate the shaft on these distributors?
« Reply #3 on: March 09, 2020, 10:25:10 AM »
A few drops of oil on the centrifugal advance mechanism. A few drops of oil on the felt that rides on the points cam. Engine oil splashes around the distributor lower shaft and bushing when the car is running.
Offline 1970 Snake
« Reply #4 on: March 09, 2020, 02:54:58 PM »
Okay, I have completely disassembled the distributor, so I was thinking assembly lube on the shaft inside the distributor, surprised enough oil gets passed the retaining collar to lube it after startup, thank you for the info.
