Author Topic: 1968 San Jose GT Coil Spring Perch  (Read 1751 times)
Offline 427Fastback
Re: 1968 San Jose GT Coil Spring Perch
« Reply #15 on: May 13, 2020, 12:39:12 AM »
Anything is possible..I have had the parts for decades and don't know the history on them.I will have to look at my other car and look at the perches.I know they are Ford and I probably bought them 25-30 years ago...I doubt my parts are what Mike is looking for so they will just go back in the box......
Offline bullitt68
« Reply #16 on: May 13, 2020, 04:19:46 AM »
Don't know what you have however early spring perches have fine threads and the bushings do not have the crimped tabs.All of the Ford service perches typically have the tabs and course threads. At least the ones made after 1967 typically do.Quite possible yours are all 65-67 early parts
Thanks for clarifying Bob. My perches as per the photos have the tabs and I have both fine thread and coarse thread nuts and bolt from a few different sets I found. I am nit sure if the bushings need to be changed or not, but if those bushing are correct I would use them as they are local. Otherwise the hunt continues...
Mike
« Reply #17 on: May 13, 2020, 12:12:31 PM »
The course thread bolts and the bushings with the tabs are most typical and that is what i would aim for IMO. The bushing in your picture without studying it too much most likely can be manipulated to have the crimped tabs but it is time consuming and difficult. Many used ones still have usable bushings. Sometimes you can even trim the outer edge of the rubber that is cracked on a otherwise ugly bushing to reveal a inner surface that is not cracked.
Offline bullitt68
« Reply #18 on: May 13, 2020, 02:11:06 PM »
Good point Bob. I will inspect my bushings again, but from what I recall they seemed to be ok last time I looked.
Mike
Offline bullitt68
« Reply #19 on: May 13, 2020, 09:15:23 PM »
How do these look Bob. I am going to get rid of the pitting, but the bushings don't look too bad to me.
« Last Edit: May 13, 2020, 09:19:42 PM by bullitt68 »
Mike
« Reply #20 on: May 13, 2020, 09:55:59 PM »
They don't look too bad. You might be able to use a dremel and blend in the surface area better to hide the trimming marks and make them look even better.
Offline bullitt68
« Reply #21 on: May 14, 2020, 12:18:51 AM »
Good idea Bob I will try that
Mike
