Author Topic: 67 backup light housing C7ZZ-15511-A vs C7ZZ-15511-B  (Read 704 times)
« on: February 27, 2020, 06:40:01 PM »
I have a line on a set of C7ZZ-15511-B and C7ZZ-15512-B which according to the MPC was introduced on 4/8/1968.
My car (December 66) should have the -A version.
The backup light document by Marcus (link below) says that the difference was only in the light bulb socket, and there are no external visual differences.
http://anghelrestorations.com/uploads/3/5/1/2/35122002/back_up_lights_v1.1.pdf
Does this mean that the bulb is a different type as well?  If not, why would Ford continue to carry both versions for service?
1967 eight barrel
  • Guest
Re: 67 backup light housing C7ZZ-15511-A vs C7ZZ-15511-B
« Reply #1 on: February 27, 2020, 07:23:54 PM »
No, same 1156 bulb.
Offline Keith Stem
« Reply #2 on: February 28, 2020, 07:25:17 AM »
The 1157 bulb will fit bulb and work, but the correct bulb is the 1142. The difference is the 1142 is a single filament and the 1157 is a dual filament (Stop and Turn Signal). I did not do a deep research of all years, but it was used in 66 to 68 and probably many more year of first generation Mustangs.
« Reply #3 on: February 28, 2020, 08:04:15 AM »
Thanks for the replies.
Back to the original question, restated:
If the only difference between the two was a change do the light bulb socket, and if the actual bulb requirements did not change, and if there is no visual difference between the two, then why didn't the revision B part replace the original revision A, instead of carrying both with a running change date?  I suspect that there has to be something more...
