Author Topic: 1966 Power steering tie rod ends  (Read 576 times)
Offline dsielke
« on: February 20, 2020, 02:20:25 PM »
I just received these and I believe they are correct originals but just want to check with the experts here to be sure. They are tight and I was planning on cleaning them up and adding new correct boots from NPD.
Do these look like original tie rod ends for a 1966 with power steering. San Jose, Dec. 1, 65 build date?
6R09A138419: 1966 GT Fastback, Springtime Yellow
6R08T138429: 1966 Convertible, Tahoe Turquoise
Re: 1966 Power steering tie rod ends
« Reply #1 on: February 20, 2020, 04:38:52 PM »
The right hand side is the same as a non power steering car. The left hand side uses a larger diameter tie rod, 3/4 inch, and the sleeve uses a bolt with a square shoulder.
Offline Crgjohnson
« Reply #2 on: February 24, 2020, 10:30:49 AM »
Hard to see but if I remember correctly many of the line tie rods had a "B" stamped on the bottom cover where the zerk is on aftermarket rods.
Craig
70 BOSS 302(Dearborn 10/69) Medium Blue Metallic, CA emissions
70 BOSS 302(Dearborn 10/69) Calypso Coral, CA emissions
09 Shelby GT 500, factory stripe delete
MCA 69-71 concours BOSS gold card judge
Mustang restorer (hobby)
69 Cougar 3/69
« Reply #3 on: February 24, 2020, 10:46:15 AM »
65-66 typically did not have that, more of a 67-up thing.
« Reply #4 on: February 24, 2020, 05:18:31 PM »
+1
Later ones had a cast/machined cup holder while the early ones were stamped (thinner) steel
