Author Topic: Color Match With Modern Formulation  (Read 1835 times)
Offline 66ba200S
« on: February 20, 2020, 12:18:06 PM »
Has anyone gone through the process of color matching '66 Arcadian Blue (Code F) with a modern formulation like PPGs? Is the reformulation "close enough" for a quality restoration? The existing paint is too faded/over painted to use it as a starting point for a color match. Thank you.
1966 Sprint 200 convertible, Arcadian Blue.
Re: Color Match With Modern Formulation
« Reply #1 on: February 20, 2020, 02:41:36 PM »
Might want to check with Auto Color Library to see if they have done a color match. Know we've worked with them a little for other colors
« Reply #2 on: February 20, 2020, 03:25:20 PM »
Boy, I can relate. Here is my tale...
If you take yesterday's formula and have the paint store run it through their system you don't get the paint color you want. That's because today's green, blue, orange, etc is not the same color as it was 50 years ago. So when you take 500 grams of today's blue, 100 grams of today's white and add them up per the old paint mix gram totals the color you end up with is not the same.
When I asked the paint store to mix up my Lime Gold in PPG DCC and I sprayed it out I ended up with something quite awful.
I asked around in this and the SAAC forum and Tim Lea shared his paint mix for Lime Gold, but it was in the Lesonal brand by Sikkens and no one within two states of me uses this paint. We can't use this mix ratio as we can't assume any of the individual colors cross over to other paint lines.
Finally we took our paint store's color match camera and shot the passenger door latch area (and other areas) of a survivor car and had them mix up a test sample.
We sprayed this out and it matched one small sliver of original paint left on my dash. I have yet to return to the original car and match our spray outs to this car.
Hopefully you have some area of the car still in original paint. Like the underside of the trunk that you can remove and bring to them. Have them mix up a very small test tube size sample and do a spray out on a spray out card. PPG DCC can still be had in single stage in some areas if that is your preference. Have them mix this if this is how you intend to respray the car. Otherwise, have them do it in a base coat system, spray it  and clear coat the spray out. Then see if the color matches.
« Reply #3 on: February 20, 2020, 04:03:22 PM »
More tales. My 66 GT Fastback is color code Y, Silver Blue. The closest match was from a mid 70's Buick. We used the  driver's door frame and underside of the trunk lid for samples. I declined.
Offline 66ba200S
« Reply #4 on: February 20, 2020, 05:19:18 PM »
Thanks. I knew it wouldn't be easy, just taking a chance that I might get lucky.
Offline Murf
« Reply #5 on: February 20, 2020, 06:35:31 PM »
The area under the package tray below the  rear window is always a good place to get a  "sample" of your color.  Have your paint store shoot this area and mix a sample.  The camera will not identify the paint miix, it will only match what it sees to a color that is now possible and is in the date base of the camera and paint  product line you are using, so it is not a fix-all for every color color match.  We matched Wimbledon White with this method and only had to tint a small amount to hit the correct color in single state PPG which gives a good representation of Ford baked acrylic enamel.  An experienced and interested painter can tint and get good results with solid colors, metallic not quite so good.  Hope this can help you in some way.
John Murphy
Offline 66ba200S
« Reply #6 on: February 20, 2020, 08:20:27 PM »
Thank you. Good idea for a place to find undisturbed original paint.
