Author Topic: Electrical issue  (Read 499 times)
Offline rrenz
Electrical issue
« on: February 18, 2020, 08:48:28 PM »
since last October I've been starting the car about once a month. a handful of times I've noticed a little smoke coming from the engine compartment. The battery cables have also gotten extremely hot if it takes a few attempts to get going. I have a reproduction solenoid. Im thinking that possibly its beginning to fail?
Ryan
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
Re: Electrical issue
« Reply #1 on: February 18, 2020, 09:04:15 PM »
Your starter cable (or battery cables) is probably on the way out; it is probably exhibiting high resistance which means lots more current is needed to go through it (and thus the wires get hot).  You allude to the fact that you need to crank it a couple of times to get it going...it all makes sense.  I'd start with the starter cable and go from there.
Offline DKutz
« Reply #2 on: February 19, 2020, 04:13:48 PM »
starter could also be going bad.
Offline rrenz
« Reply #3 on: February 19, 2020, 07:51:50 PM »
I had considered both. The starter, solenoid and cables were all replaced at the same time about 3 years ago. the starter I've had issues with since day one as it doesn't seem to retract fast enough and will occasionally do some grinding. perhaps ill start... with a starter
Ryan
C-4 Automatic
Build Date Jan 21st
Offline DKutz
« Reply #4 on: February 20, 2020, 12:20:46 PM »
I had issues with my car starting then a friend noticed my cables were cooking!  I took the starter in for a rebuild and all is good now.
