Author Topic: 1966 fender spacers?  (Read 937 times)
Offline evantugby
« on: February 12, 2020, 06:18:27 PM »
Team,
Can you confirm if fender spacers were placed under the fenders in between where the bolts hold fender to engine bay?  If I remember correctly there were “shims” in between.  If so, did all mustangs have this to help line up the fenders correctly or were these only used as needed?
Re: 1966 fender spacers?
« Reply #1 on: February 12, 2020, 06:49:12 PM »
They were not typical used  IMHO. Rarely have I found a single one on an original car. Same findings through the early 70 cars. More often used by body shops during later repairs and such. Have to consider that the somewhat weak inner fender edge (bend with ease if you rest a heavy hand on them  ::) so they are not going to help allow expect for the far forward, rear or at the shock towers
Sometimes shops will use the aftermarket upper A arm shims (they look different) for this purpose also during repaints and repairs. On later cars the factory shims are shaped much differently
« Last Edit: February 12, 2020, 11:14:43 PM by J_Speegle »
« Reply #2 on: February 12, 2020, 07:20:49 PM »
A "spacer"? Yes and no. It was "disguised" as a flat washer (44725-S2, 5/16FLW, 0.365-0.385ID, 1.125OD, 0.051-0.080T). The 64-66 body assembly manuals said 5 maximum each side, for use where the fender meets the door, and fender to rocker panel. Nothing for fender to cowl.
Offline mgmradio
« Reply #3 on: February 12, 2020, 08:13:34 PM »
Interesting Jeff. My experience is the exact opposite. I can't recall seeing an unrestored Dearborn car that didn't have alignment shims under the front of the fender. My August 64 coupe and both June 65 cars have them , though the right one on my convertible was removed and is wedged between the grill and radiator support.
Offline evantugby
« Reply #4 on: February 12, 2020, 08:22:59 PM »
Gents,
I want to make sure we are talking about the same area. See the attached photo with yellow highlights as the area that I believe some shims or “washers“ were placed in between the fender bolts.
Is this the same area you are talking about?
« Reply #5 on: February 12, 2020, 08:46:12 PM »
Gents,
Washers placed in the area of the yellow highlights are not typical on the assemblyline. Speaking of washers 6S1732 Shelby typically would have stiffing washers welded to the upper shock beehive under where the upper shock bolts. They seem to be missing in the picture.
« Reply #6 on: February 12, 2020, 10:45:39 PM »
Yes interesting. Or course we're comparing 65 verse 66 and Dearborn verses San Jose for  the OP's focus
I'm guessing (you can confirm) that your describing the shims being found only under the two front bolts at the inner fender and radiator support locations looking at the pictures I have of the cars.  Not all or any at the other locations
Three pictures from Mikes green car
No apparent shims
One at the front bolt location
And from another 65 Dearborn example we have in the unrestored picture section. We even included a comment on them when those pictures were posted a few years back
Took a very quick peek at 66 Dearborn and found a number of cars with a shim on one side or both. Right now is appears allot more popular for cars built at Dearborn
Might be a good discussion in another thread focusing on other years and all plants
« Reply #7 on: February 12, 2020, 10:47:48 PM »
Washers placed in the area of the yellow highlights are not typical on the assemblyline. .................
+1  Not washers and not at those locations if they ever used them.
Shops have been know to use or insert cut off paint sticks also as shims  ::)
Offline mgmradio
« Reply #8 on: February 12, 2020, 11:08:59 PM »
I have never seen washers or shims at those locations, only under the front corners and they have always been alignment type shims.
« Reply #9 on: February 13, 2020, 11:50:50 AM »
+1, only washers are sometimes on the farthest back fender bolts, usually some Metuchen cars.
« Reply #10 on: February 13, 2020, 06:18:50 PM »
Just checking - but guessing your describing what would likely be considered an "extra" larger washer between standard bolt and captured washer and the top of the fender like shown below.
65 Dearborn example - Mike's green coupe
66 NJ example
Haven't identified a pattern yet for either
« Reply #11 on: February 13, 2020, 09:47:28 PM »
The extra washer under the bolt head but on top of the fender itself doesn't do anything for affecting spacing, IMHO.
