Author Topic: 1968 San Jose GT 390 Fastback Clutch & Brake Pedal Assembly  (Read 3141 times)
Offline bullitt68
Mike
Offline preaction
Re: 1968 San Jose GT 390 Fastback Clutch & Brake Pedal Assembly
« Reply #32 on: January 25, 2021, 06:59:15 PM »
Does anyone recognize this attached bracket I didnt see it on the OP's or on the pedal support Royce posted pics of this was removed from a mid July Dearborn PDB 4sp car with no options. The screw fastening it does look like a typical Ford self tapping screw from that time.
« Reply #33 on: January 25, 2021, 07:14:31 PM »
If you are referring  to the zinc plated one it is to hold the flasher unit.
Offline preaction
« Reply #34 on: January 25, 2021, 08:21:03 PM »
Thanks Marty.
Offline preaction
« Reply #35 on: January 26, 2021, 05:15:20 PM »
Should there be a fastner wired to the flasher pigtail that mounts to the unique size hole thats on the bracket as Im going through my harness I only have the pig tail, connector and flasher.
« Reply #36 on: January 26, 2021, 05:54:33 PM »
Not being a "68" specialist but doesn't the original plastic housing flasher have a square knob that shape? Does it simply twist lock into place?
I quickly looked for a picture, found a Wagner, I believe original supplier was Tung-Sol but picture is for reference to the "knob".
« Last Edit: January 26, 2021, 05:58:52 PM by 67gtasanjose »
« Reply #37 on: January 26, 2021, 10:50:24 PM »
+1 Marty
Offline preaction
« Reply #38 on: January 27, 2021, 02:13:02 PM »
My 2 flasher cans are aluminum Autolite C8ZB flasher cans without the nub.
« Last Edit: January 27, 2021, 02:16:10 PM by preaction »
