Author Topic: Color interior mirror, rimblow steering wheel and dash?  (Read 603 times)
Offline Harry1003
« on: February 09, 2020, 01:15:52 PM »
Hello,
can someone tell me what color the inside mirror, the back of the rimblow steering wheel and the upper dash was.
The car has the white interior.
All three parts of my car are black, is that correct?
Car: 1969 Mach 1, build at SJ, 03/11/1969, 351W
Thank you in advance!
Greetings Harry :)
Re: Color interior mirror, rimblow steering wheel and dash?
« Reply #1 on: February 09, 2020, 05:15:45 PM »
69 Mach I with white interior
inside mirror- Molded in black plastic
Back side of rimblow steering wheel - Molded in a black/Dark charcoal colored plastic or resin based material
Upper dash - Dash pad is/was black - lower painted metal surfaces and the dash pad extensions were painted (two different shines) Dark Charcoal Metallic as described in the article in the Library and other threads
« Last Edit: February 09, 2020, 05:26:01 PM by J_Speegle »
Offline Harry1003
« Reply #2 on: February 09, 2020, 06:18:25 PM »
Hi Jeff,
that helps a lot.  :)
Many many thanks!!!
Greetings
Harry
