Author Topic: '65 Coil Date Code  (Read 10311 times)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Re: '65 Coil Date Code
« Reply #15 on: December 18, 2010, 08:15:28 PM »
MAN!!!!   That's a little short "squatty" thang!
66 Metuch Conv
Nightmist, Std Blu Int
« Reply #16 on: December 18, 2010, 08:33:19 PM »
The line up of the AUTOLITE and the rest of the boxes and such appears off in your artwork (just offering constructive input of course ;)
Unfortunately can't up load an original example and new art this moment
Offline Twilight65
  • Gold Level Subscriber
« Reply #17 on: December 18, 2010, 08:44:33 PM »
No problem Jeff. Thats why I made the artwork and then printed it on a clear plastic sheet to get it to match my original. I must of printed and cleaned that plastic sheet 20 times as I held it over the coil to get it to match. It may be off a little to another coil but it matched my original and that's what I was after.
Dave
Offline mgmradio
« Reply #18 on: December 18, 2010, 10:32:08 PM »
The lined aria around the date code on my Aug 64 coupe is different from the ones on your 66 stamp.Instead of being straight above and below the date they are curved.
Offline ChrisV289
« Reply #19 on: July 07, 2015, 12:50:53 AM »
Sorry to bring a long dead article back but thinking about getting a stamp made for my coil.  Is Staples the best place to have this made and if so, what type of stamp as they have several to choose from:
http://www.staples.com/sbd/content/copyandprint/stamps.html
2009 V6 Mustang Coupe
« Reply #20 on: July 07, 2015, 01:00:18 AM »
Most likely they will refuse do to copywrite concerns. Heard a number of stories lately of guys getting refused based on that concern by the stamp making companies
Also would be concerned if they would not redo/substitute your fonts for "stock" fonts
As for what type of stamp it depends on hoe you plan to install/apply it and how you plan to "ink" the stamp.
You can choose to roll the stamp on the part (in this case a coil) or roll the part on the stamp. Placed or attached stationary while you move the coil over the stamp.
Haven't measured my coil stamps in a long time but see the post with those measurements - have you checked if they make them that large? And if so that might limit your choices going through them.
There are companies that make signs and such that make stamps
« Last Edit: July 07, 2015, 01:04:17 AM by J_Speegle »
Offline Texas Swede
« Reply #21 on: July 07, 2015, 08:13:26 AM »
On my car, an early May 65 GT350, the stamp is completely hidden behind the
mounting bracket when mounted in the original position.
Texas Swede
Offline Richard P.
« Reply #22 on: July 07, 2015, 02:12:19 PM »
Texas Swede
I've seen a number of early cars (1965/66) where the stamping was hidden behind the coil bracket. The MCA rules state that the stamping should be visible. This should be changed as that wasn't always the case.
« Reply #23 on: July 07, 2015, 04:44:12 PM »
The wording might be tricky since, if the owner choose, mounting the clamp high on the coil would not hide the stamp. Wording would IMHO need to include where the clamp & coil  need to be orientated if the stamp is not going to be visible or your just giving all the owners a free pass  and not representing how the car were build.
Just a thought
« Reply #24 on: July 07, 2015, 05:47:06 PM »
Agree.  Should also not allow the decals, but that's another subject altogether.
« Reply #25 on: July 07, 2015, 05:49:13 PM »
agree with charles. we tried to eliminate the decal at the last judges meeting but was overruled by those in charge. it was decided to leave the stamping for t-bred only.
« Reply #26 on: July 07, 2015, 06:28:39 PM »
........ we tried to eliminate the decal at the last judges meeting but was overruled by those in charge. it was decided to leave the stamping for t-bred only.
 ::)  Remember when the body (the judges) use to vote on things and that was what got carried forward to the board for approval
Does not one good to hold the standard for restored cars so low that it allows things that were never used originally as a poor substitute for what was. And it no way allows owners who do it right any reward for their efforts
SOrry for getting off subject.
Offline Richard P.
« Reply #27 on: July 07, 2015, 06:40:00 PM »
Texas Swede
If the coil bracket covered the stamping on cars like Texas Swede I can't see where we'd be giving him or anyone else a pass, if that's what Ford Motor Company did. We must remember we don't make the rules. The guidelines were made by Ford when they built those cars.
« Reply #28 on: July 07, 2015, 08:39:31 PM »
If the coil bracket covered the stamping on cars like Texas Swede I can't see where we'd be giving him or anyone else a pass, ......
Let me try and explain my comment better
If an owner chooses to mount their coil so that the band covers the top quarter (approximately) of the tube or side of the coil and the stamp as we know, was typically applied to the bottom 1/3-1/4 if the rules are not written carefully, could they not claim that the stamp is not missing but its "under the clamp" like the rules would apply.
Just a predictable situation IMHO.
Would rather see nothing instead of the clear decal with the 70 date code :)
Offline Richard P.
« Reply #29 on: July 07, 2015, 09:15:10 PM »
I must agree with you, I'd rather see nothing than see something that's wrong. In a lot of cases you'll see nothing and that's the way it was.
