Author Topic: 289 (65-67) Block Date Stamp Study/Survey  (Read 4230 times)
« on: February 08, 2020, 07:57:26 PM »
Figured we would start small and focused study then we can move to later years and other engines once we get this step addressed and if it bears any fruit
The question - Is the assembly date and assemblers initial stamped on the small protrusion at the front drivers side of the block where the head attaches the assembly date of the short block or the completed engine?
For years we have taken it to mean the completed engine but let's see what the findings suggest and discuss
To collect information we need at least
1- Engine block casting date
2- Assembly date stamped on the small extension/protrusion
3- Casting dates of the heads, intake, dist, exhaust manifolds believed to be original to the block
4- Engine ID aluminum tag information
The findings may not be as defining as other surveys since individual items could be cast before and installed after if that was what was done.
Lets see where this leads us
Thanks for viewing and considering participation
« Last Edit: February 08, 2020, 08:00:27 PM by J_Speegle »
Re: 289 (65-67) Block Date Stamp Study/Survey
« Reply #1 on: February 08, 2020, 09:56:05 PM »
Jeff, here is the info from my car.  I've added a few more items to what you originally requested, and also noted what I know is not original.  I can dig out the harmonic balancer later if needed.
Offline 6R07K
« Reply #2 on: February 09, 2020, 02:49:47 AM »
Hi,
Below is what I have handy for 6R07K193XXX
Block casting 6B19 -            19th Feb 1966
Heads are both 6B25 -         25th Feb 1966
Intake manifold 6D5 -           5th April 1966
Distributer 6D7 -                  7th April 1966
Stamped Assembly 6D19L - 19th April 1966
VIN is stamped on the block
Door tag schedule build 02E - 2nd May 1966
« Last Edit: February 09, 2020, 07:55:45 AM by bmsa66 »
Cheers
Ben
6R07K193XXX
Offline Blue_67_Fastback
« Reply #3 on: February 09, 2020, 07:38:02 AM »
Hallo Jeff,
just took off the starter for the last missing Number…
This is what I found:
Block casting       7B21
Heads are both    7B22
Intake manifold    7B21
Distributer       7A3
Stamped Assembly    7B23
Engine Tag       7-B
Exhaust Manifold    7B21  (right)
Exhaust Manifold    7B13  (left)
Balancer / Timer   B7
Vin is 7F02C169xxx
Car Build Date    03/02/67
Enno
1967 Fastback, C Code, 3 Sp MT, 7F02C169xxx, Build Date 3/2/67
First Mustang Club of Germany 1964-73 e.V.
« Reply #4 on: February 09, 2020, 04:35:25 PM »
From my 66 GT Fastback:
VIN:                6R07K121xxx
Door:              63B Y 62 18K 72 5 6
Sched Build:    18 Oct 65
Eng cast:         5H11 11 Aug 65
Eng assy/Insp: 5H23 23 Aug 65
Intake:            5G27 27 Jul 65 (C6OE-9425-B)
Carburetor:      5GD Jul 65, 4th week
Distributor:      4FD Jun 65, 4th week
Heads:            TBD, I'm not pulling the valve covers off for this.
Radiator:         W-MO 9-65
Sold:               28 Oct 65, Mountain View, Ca
Exh Mfld:         TBD
Offline BryceDouglas
« Reply #5 on: March 22, 2020, 06:59:23 PM »
Here is the info on my 1965 C code coupe.
5R07C19424XX
Projected build date D8
DSO 71
Offline lancelot66
« Reply #6 on: March 24, 2020, 11:34:39 AM »
Hi Jeff,
For our A code Fastback:
Engine ID aluminum tag information:
289 C 66 10
5-M E 235-S
VIN:                6R09A150xxx
Door:              63A M 25 71 1 6
Sched Build:    06 Jan 66
Eng cast:           5M23 (C5AE-6015E)
Eng assy/Insp:  5M28 I or 1
Intake:            5M8 (C6OE-9425-B)
Carburetor:      5MB
Distributor:      5LC (C6ZF 12127 B)
Heads:            Original Thermactor, but TBD
Exh Mfld:         Left Side only: 5M21
Steering Box: HCC AW, 5M23B
Trans Tag:        PCW, AS, 289 5M23 C 1
Steel Wheels/Rims:  5MM
« Last Edit: March 24, 2020, 11:51:52 AM by lancelot66 »
VR/
-Lance
SJ Build Date: 1/6
Many Original Options
« Reply #7 on: March 24, 2020, 11:52:10 AM »
Jeff: did you get the codes from the red '65 coupe you helped with?  I have the engine apart, can get all the info if needed.
« Reply #8 on: March 24, 2020, 03:19:41 PM »
No I didn't pull the starter nor the valve covers
Offline Deuce
« Reply #9 on: April 01, 2020, 03:44:41 PM »
Using this Stay at Home opportunity to catch up on lingering projects.
For our 1967 C code hardtop coupe:
Engine ID aluminum tag (Internal port Thermactor engine):
289 E 67
L E 236-B 15
(see Note #1 below)
VIN: 7R01C147xxx
Door: 65A Y 2G 06M 71 0 W
Sched Build: 12/06/66
Actually Built: 11/30/66
Eng Cast:  6L23 (C6AE-6015-C)
Eng Assy/Insp: 6L25 S
Intake Manifold: 6L10
Carburetor: B 6LC (C7DF V - Autolite 2100)
Distributor:  Service part w/later casting no. (See note #2)
Heads:  LH: 6K25; RH: 7E23 (See Note #2)
Exh Manifold:  LH: 6L14; RH: 6L11
C4 Trans:  TBD
Steering Box & PS pump:  TBD
Steel Wheels (five incl spare): 6MK
Note 1:  Original 289 engine is still in the car. In June 1983 the engine was rebuilt and re-installed (long block) at 293,450 miles by an authorized Ford reman facility in San Diego.  The car with Ford reman engine now has logged a total of 541,000 miles, or an additional 248,000 miles since the rebuild. 1983 Ford rebuilt engine warranty: )
Note 2:  During the engine reman process, the RH cylinder head was not suitable for reconditioning and replaced with a '67 289 Thermactor head cast in July May 1967. Distributor was replaced during engine reman with a Ford service part.
« Last Edit: April 03, 2020, 09:46:50 AM by Deuce »
Deuce
Offline warwick
« Reply #10 on: April 01, 2020, 05:29:10 PM »
Jeff,
I don't have all my dates but two of the dates I have are relevant to the question you are researching.
Assembly date: 5M1
Intake Manifold Casting Date:  5M3
« Reply #11 on: April 01, 2020, 07:34:13 PM »
Deuce - Same markings on Trans and steering??
Steering box has a cast date on the main body and a tag (assembled) date on the tag
Thanks guys for the continued input and support of this study
« Last Edit: April 01, 2020, 07:41:01 PM by J_Speegle »
Offline TonyFio
« Reply #12 on: January 16, 2022, 07:41:50 PM »
My engine and trans are out, so it was easy to get info:
VIN: 5R07C226xxx
Scheduled build date: 5/28/65
Body: 65B
Block casting                    5E20
Head (passenger side)    5E24
Head (driver side)            5E25
Intake manifold                5E17
Distributor                        not original
Stamped Assembly           can't read
Engine Tag (not orig)        5E
Exhaust Manifold (pass)   5E3
Exhaust Manifold (dr)       5E13
Intake Manifold                5E17
C4 middle section cast     4/65
C4 data tag (original)      5E28
« Last Edit: January 17, 2022, 01:33:24 AM by TonyFio »
Tony Fiorenza
65 Lux Coupe, SJ built, 5/65, owned since 1974
« Reply #13 on: January 16, 2022, 10:37:13 PM »
