Author Topic: Special character in Date Code/Shift on Crossmember  (Read 916 times)
Offline 68Metuchen390GT
« on: February 04, 2020, 11:08:18 PM »
Need a bit of help, I found a crossmember that is advertised as a 67-68 390 toploader crossmember. The shape of the part appears to be a late 68 crossmember with the notch for the speedo cable. I have never seen the special character stamped in the date code,  I checked the date code section of the library and couldn’t find anything with the special character that appears to be a circle with an A or a “@“. Is this a service part or a repo? It may be a later year, I’m not very familiar with the 69 and later cars. Thanks
Richard
1968 Mustang GT 390 Raven Black, 4 Speed
8T02S212765, Metuchen, June 19, 1968
Re: Special character in Date Code/Shift on Crossmember
« Reply #1 on: February 05, 2020, 02:41:12 PM »
Haven't seen an "A" in a circle that I can recall There was a period of time when some of the stamping plants were using an "A" on the parts they were making. Not to be confused with other letters stamped in a circle stamp during other periods
These ("A") were applied during a period of time after the cars were built - service replacements. Right this moment don't recall the year spread when this was done but have it in my spread sheets
« Reply #2 on: February 05, 2020, 08:41:38 PM »
Thanks so would it be safe to say this wouldn’t be a fresh from the factory assembly line part?
« Reply #3 on: February 06, 2020, 04:45:16 PM »
That would be my current belief and interpretation of the stamping
Offline DTruitt
« Reply #4 on: February 06, 2020, 10:16:28 PM »
Check out this post on the 428Cobrajet forum.  The 390 / 428 used the same cross member.  You will see the difference between the 68 version and the 69-70 version.
https://www.428cobrajet.org/forum/index.php?topic=25959.msg175278#msg175278
Danny
1968 Raven Black, S- Code, 4 spd., GT Fastback, San Jose, March 1968
1968 Candy Apple Red, J- Code, C-4, GT Convertable, San Jose, April 1968 (SOLD)
1968 Raven Black, R- Code, 4 spd., GT Coupe, Dearborn, April 1968
MCA Gold Card Judge
« Reply #5 on: February 06, 2020, 10:46:23 PM »
This thread seems to indicate the large groove is at least a July 1968 change in the crossmember and not specific to 69 but a this would maybe been a 69 part used on 68s. This would be worth of a changeover thread for 68.
http://www.concoursmustang.com/forum/index.php?topic=18573.msg117486#msg117486
Offline CT428CJ
« Reply #6 on: February 07, 2020, 10:35:37 PM »
And maybe earlier based on the added feature to clear larger diameter exhaust systems.
« Reply #7 on: February 08, 2020, 10:08:44 PM »
I wonder when this notch first occurred, is there a list of changes from the assembly line? I see some parts like clutch forks that changed in Feb 1968, could this be when the changes occurred.
« Reply #8 on: February 08, 2020, 10:33:12 PM »
Here is some in from the 68 MPC.
Looks like for 67 & 68 there were four variations of the engine rear support cross member, part numbers C7ZZ-6A023-A, -B, -C, and -D.
The version I have is a bit early for the 428 CJ, not a lot of CJ parts listed, only a few.  I did not look at 69 or later parts in other MPCs.
It is interesting that the 6 cylinder and 289 version moved from -C to -D for 1968, but the 302 lists the -C.
The 390 parts appear to be different for auto vs. manual trans, where as 6 cylinder and small blocks share the same part.
I don't see a running change in 68, the MPC I have has updates up to June 68
« Last Edit: February 08, 2020, 10:35:54 PM by 67gta289 »
« Reply #9 on: February 08, 2020, 10:34:23 PM »
No list that I know of. Sure we will start a running changes thread at some point for 68 as we've done for some of the 65-67 years
If you want start a thread just on this particular piece, rather than continue in this thread and later we can link it later to a master list one established.
