Author Topic: Fuel Filter Spring  (Read 641 times)
Offline pstone
Fuel Filter Spring
« on: January 27, 2020, 05:31:00 PM »
Would there have been a spring with the fuel filter inside the canister or was there only the filter in a late (August) 1965 engine? 289 V8 2V.
Re: Fuel Filter Spring
« Reply #1 on: January 27, 2020, 06:06:13 PM »
In this instance the fuel filter did not need a spring. The filter was held in place by a interference fit rubber O ring/gasket made into filter . Also the flow of fuel through the filter and up through the O ring /gasket opening of the filter would also help hold it in place vs. the opposite.
Offline pstone
« Reply #2 on: January 27, 2020, 06:17:25 PM »
Thanks Bob.  I appreciate your help.
Offline ChrisV289
« Reply #3 on: January 27, 2020, 11:35:08 PM »
I found a spring in a fuel pump I got from a guy. Had the original white with lettering canister.  Thought maybe it was a fluke.
2009 V6 Mustang Coupe
Offline Snydly289
« Reply #4 on: January 28, 2020, 12:47:04 PM »
I also have found a spring inside the original white with red lettering canister. I attained the fuel pump from a collapsing body/mechanic shop/barn. The fuel pump however is a Carter X 3734S fuel pump dated October of 63. Not sure if this helps at all
65 K Code Fastback -5F09K325XXX, Oct. '64, Vintage Burg, Rally Pac, Arvinode Exh, lots '64 items
66 A Code GT Coupe -4 speed, bench Seat, P/S, A/C, Rally Pac, handling package, 8 track
66 A Code Fastback -Built 302, 66 S2MS Intake, WC T-5, 4-wheel Wilwoods, locking 9"
66 T Coupe
65 T Code Fastback
