As we've done for other years it appears it time to at least start a thread covering 68 running changes.
Will continue to add suggestions for individual running changes here in this thread while will be the basis for related link threads focused on each individual subject. Remember to keep these 68 San Jose focused here please not for cars and findings from other plants or years. We can cover those in additional thread or work them into this one later after a re-title and adding some subsections. We'll see how it goes
To keep the thread from getting too long or out of hand please don't post that you found this version or that on car 8R02C2345xx (for example). We can save that for the research period and for the individual running change threads as we have for other years so far. Just trying to identify the features during this first effort. Will break out the findings by plant of course. Hope we can work through other plants also. Since this is likely to get to be a very long list I think that unlike the 66 version I will break the lists out by general area of the car to keep it a little more organized. We'll see how that works.
We will drop items and discovers if its determined that a detail is not a true running change but was a result of some other finding.
If you post suggestions for items to be included I will delete your posting after it has been incorporated rather than let the add to post run on for pages
DRIVETRAIN-Engines- DE1-
390 4V Intake "S" casting - Large or small - Discussion and examples
http://www.concoursmustang.com/forum/index.php?topic=20376.msg128632#msg128632DE2-
289/302 Air cleaner snorkel - Vacuum to thermal divert plates - Discussion and examples
DE3-
289/302 Air conditioning brackets and pulleys - May need to break the discussion threads down to multiple ones - Discussion and examples
DE4-
DE5-
DE6-
Transmissions-DT1- Manual transmission
shift levers trunion size change. - Discussion and examples
DT2-
DT3-
Rear End- RE1-
ENGINE COMPARTMENT-EC1-
Hood hinge - Discussion and examples
Non-plant focused discussion
http://www.concoursmustang.com/forum/index.php?topic=21649.0EC2- Large/Extra Cooling
radiator upper clamp change - Early version had sharp ends that dug into radiator. TSB Article #1319 states "Fixed in production after Nov 1967"
http://www.concoursmustang.com/forum/index.php?topic=22682.new#newEC3-
Power Brake Check Valve Change. Early to late style change over point
EC4-
EC5-
EXTERIOR/BODY RELATED-E1-
Rear quarter reflectors - recessed to surface mounted
E2-
Lower door hinges - Cast iron to stamped steel
E3-
Rear valance screws - Please designate head type and location since these were installed at two different points in the assembly line
E4-
Coupe vinyl top drip rail strip - Change from "snap in" to riveted at critical points in Oct 1967 production according to TSB #1216 published in the following thread. Reply #51
https://www.concoursmustang.com/forum/index.php?topic=8032.msg175969#msg175969E5-
Deluxe hood insert rattle - After cars built October 1967 a small daub of sealant was applied to address rattle complaints of customers. Published in TSB #1217
https://www.concoursmustang.com/forum/index.php?topic=8044.msg46279#msg46279E6-
E7-
E8-
INTERIOR-I1-
Arm rest - Two hole verses three attaching holes/screws. Discussions and examples
http://www.concoursmustang.com/forum/index.php?topic=21730.0I2-
Pillar pads -
I3-
Knee pad -
I4-
Radio Bezel -
I5-
Bucket seats- According to TSB #1233 there was a changed made prior to Oct 1967 in the welding of the upper seat frame and a second back stop bumper installed in the base frame/seat section at or around the same time.
https://www.concoursmustang.com/forum/index.php?topic=28866.msg175971#msg175971I6-
I7-
I8-
TRUNK-T1-
T2-
T3-
T4-
T5-
T6-
TRUNK-T1-
Coupe and Convertible Trunk Spring Insulator- Change from a rubber/plastic spiral wrap on one spring rod to a simple thin wire clip that held the two rods from one another. Both installed prior to exterior paint application.
T2-
T3-
T4-
T5-
T6-
UNDERCARRIAGE & SUSPENSION-US1-
US2-
US3-
US4-
US5-
US6-
Last Updated - 9/18/2023
