Author Topic: 68 four speed shifter restoration  (Read 547 times)
Online ruppstang
« on: January 16, 2020, 09:14:40 PM »
I am restoring the four speed shifter for our 68 S code project. I am looking for the black plastic sleeve that goes in side the reverse lock out release knob.
It is about .49 inside diameter and .57 outside diameter.
Offline preaction
Re: 68 four speed shifter restoration
« Reply #1 on: January 17, 2020, 12:51:52 PM »
NPD maybe if not a new part may need to be made out of nylon. I didn't need to replace that part on my shifter.
« Reply #2 on: January 17, 2020, 01:03:27 PM »
try here.   Bill Heeleys phone number is 240-449-0635
« Reply #3 on: January 17, 2020, 02:48:08 PM »
That's interesting.
I have a few of these levers and some have the black plastic and others don't.
Since the levers aren't marked, what years apply to with and without the plastic?
[I didn't look to see if there is thread that covers all shifters].
Online ruppstang
« Reply #4 on: January 17, 2020, 02:57:52 PM »
I can not say for sure about other than 68 but I think they all had them.
Bill Heeleys does not have them. He has been trying to have some made.
Last night I wen to the hardware store and found a tube that packaged a masonry bit that is just about perfect except it is yellow I'll will have to dye it black.
I will let you know how it turns out.
Online ruppstang
« Reply #5 on: February 14, 2020, 09:47:44 PM »
I completed the restoration on the shifter assembly and the drill bit packing case worked perfectly for the lock out glide. It slides up and down smoothly.
