Author Topic: Unknown wire connection- SJ 65 FB  (Read 879 times)
Offline ChrisV289
« on: January 11, 2020, 11:24:52 AM »
Been looking at wiring diagrams for the past two days and can’t seem to find this wire. It appears to be coming from the engine gauge harness, has a female end and a red stripe. Nothing was connected to it before I started tearing down some of the car. Any ideas? I thought maybe it might be for the shifter light indicator on an automatic transmission but not sure. Car was a 4 speed then converted to an automatic and is going back to a 4 speed.
2009 V6 Mustang Coupe
Offline PraireBronze
Re: Unknown wire connection- SJ 65 FB
« Reply #1 on: January 11, 2020, 01:20:37 PM »
Pretty sure that's for the courtesy light at the back of the console.
- Tim -
1965 Prairie Bronze 2+2 (under construction)
Build Oct '64 San Jose
289 4V Automatic Transmission (A-code clone :P )
Black Std Interior
AC, PS, Style Steels, 1" Drop, Konis
Aluminized 2 1/4 Exhaust, Tri-Ys
« Reply #2 on: January 11, 2020, 02:50:03 PM »
If I recall correctly the color pattern is for interior lights and also consider that not all female connections in the main wire loom are not used on all cars. Believe PraireBronze is correct and that is often used for the console feed
Offline ChrisV289
« Reply #3 on: January 11, 2020, 03:07:45 PM »
It did originally come with a full length console and the wires are still there by the shifter and the lights did work. Tried tracing the harness but it disappears behind the firewall pad and goes up. Not sure where it goes or how it is wired.
« Reply #4 on: January 11, 2020, 04:15:15 PM »
Wires running behind the firewall pad??
Offline ChrisV289
« Reply #5 on: January 11, 2020, 04:17:18 PM »
Quote from: J_Speegle
Yeah I took the carpet out to see where it was going and it went behind the firewall pad and up near the engine guage harness I suppose I can look behind the dash and see if I can see if coming out as I have the instrument cluster out...
Offline ChrisV289
« Reply #6 on: January 11, 2020, 04:25:05 PM »
Found where the harness is connected. Appears to be an original harness. That one wire in question is still hanging out doing nothing so maybe that is it’s job?
« Reply #7 on: January 11, 2020, 08:41:10 PM »
Ahhh...what threw me was the lack of harness tape and the location: the passenger side of the engine gauge feed harness plug that goes into the firewall.  That female plug is for the PRNDL lamp, which is only used if you have an automagic transmission.
« Reply #8 on: January 11, 2020, 10:39:47 PM »
Like this example from around the same time - same plant though they should all be pretty much to the same on this details
Offline ChrisV289
« Reply #9 on: January 12, 2020, 04:39:45 PM »
This is how my shifter light was wired. Was also tied into the rally pac for some unknown reason. Needless to say this is going in the garbage  since I don’t need it anymore.
« Last Edit: January 12, 2020, 09:32:38 PM by ChrisV289 »
