Author Topic: 65 Dearborn VR suppressor location  (Read 918 times)
Offline rtate
« on: January 07, 2020, 12:29:00 PM »
I have a December 64 built Dearborn  convertible (with power roof, don't know if that makes a difference )
I would like to add the noise suppressor at the VR but don't know the exact location.
Does anyone have a photo that I could use ?
« Last Edit: January 07, 2020, 05:09:36 PM by rtate »
December 10/64 Dearborn K code, Convertible
Silver Smoke Gray
Re: 66 Dearborn VR suppressor location
« Reply #1 on: January 07, 2020, 03:11:58 PM »
I have a December 65 Dearborn convertible (with power roof, don't know if that makes a difference )
Sorry I could not find a clear picture taken from under the area/voltage regulator for that year and plant
It was mounted to the bottom mounting screw and faced towards the outside/drivers side/plug side of the car
Picture barely shows the wire leading to it below
Offline rtate
« Reply #2 on: January 07, 2020, 03:57:07 PM »
Thanks Jeff !
I was hoping that it would be in a more visible location so I could show of my shiny new part   :)
And the new tag !
Silver Smoke Gray
Re: 65 Dearborn VR suppressor location
« Reply #3 on: January 07, 2020, 05:01:20 PM »
Remember two staples in the tag :)
Offline rtate
« Reply #4 on: January 07, 2020, 05:03:51 PM »
I have ordered the tag and suppressors from Virginia Classics , will it have the staples in place ?
Silver Smoke Gray
« Reply #5 on: January 07, 2020, 05:26:19 PM »
Don't know since I've not ordered one. Not sure if the one closest to the fold (if in place) would allow it to be slipped over the plug at the end with ease but you will have to check when it gets there.
« Last Edit: January 07, 2020, 05:44:22 PM by J_Speegle »
Offline dkknab
« Reply #6 on: September 06, 2022, 04:13:55 PM »
I'm assuming by now you received the red tag and installed it.  Would you be able to post a picture of what you ended up doing please? I need that tag too but am not sure how it gets stapled in place from the earlier picture. It does look like the tag is folded in half them stapled near the wire I believe.
David Knab
289 2V, AT, PS
Nugget Gold Interior
« Reply #7 on: September 06, 2022, 06:57:19 PM »
Its stapled very close to the wire to keep if from slipping around and at the end (minus maybe 1/8" -1/4" ) from the very end to hold the ends together and make the print easier to see
Will look for a better picture to post
« Last Edit: September 06, 2022, 08:05:39 PM by J_Speegle »
« Reply #8 on: September 06, 2022, 08:06:13 PM »
Examples of staple location and direction of staple installation
