Author Topic: 67 289 thermactor gaskets at heads  (Read 596 times)
« on: December 31, 2019, 06:21:12 PM »
Referencing the attached picture, I'm looking for what to do with items 37 (C7OE-9C436-A) and 39 (C7OE-9C435-A or C7DE-9C435-A).  The MPC lists C7OZ-9C435-A and C7OZ-9C435-B for these.
I'm not finding them available for purchase.  Any suggestions? Thanks
Re: 67 289 thermactor gaskets at heads
« Reply #1 on: December 31, 2019, 06:26:13 PM »
I should mention that I did a fair amount of searching, as well as looking at pictures of unrestored cars.  Nothing really helpful thus far.
« Reply #2 on: December 31, 2019, 07:05:18 PM »
These are made of copper.
I found the small ones in a Napa store brake caliper hose attaching banjo nut seal assortment.
If memory serves, the large ones I sourced some that would work by i.d. size, I could not match the o.d. size. Hydraulic hose banjo bolts, think tractors, Bobcats, farm implements.
I believe I ended up using my old ones over again.
« Reply #3 on: December 31, 2019, 07:45:09 PM »
That helps a lot, thanks Richard
Offline 7R02A
« Reply #4 on: January 01, 2020, 01:04:26 AM »
I went thru this a couple of years ago.  Like Richard, I reused the 2 small washers and I only had 1 of the large ones.  I could not source one, so I made one.  Luckily, I measured and recorded the measurements of both washers.
Small washer:  OD-.633”, ID- .330”, thickness- .030”
Large washer:  OD-.1.130”, ID- .860”, thickness- .030”
This is for the car listed in my signature.
Hope this helps a little,
1967 Fastback, A code, automatic transmission, Deluxe interior, AC, PS, P disc brakes, tilt, consoles, exterior group, fold down, DSO 71.
San Jose build, Actual build: Dec 17, 66.
« Reply #5 on: January 01, 2020, 07:32:12 AM »
Most excellent!
I did not cite dimensions because I didn't record them.
Honestly, I seem to recall starting a thread before, maybe in the wanted section.
« Reply #6 on: January 01, 2020, 10:04:59 AM »
Agreed, thanks John.
Comparing your numbers with those from the MPC, they look reasonably close for the function served.
Offline bgp429
« Reply #7 on: January 01, 2020, 11:42:55 AM »
Have you tried Ace Hardware?
« Reply #8 on: January 01, 2020, 02:23:10 PM »
Not yet. The smaller one is fairly common.  The large one not do much.  I found something close online, but I need to measure the part to ensure it will fit.
