Author Topic: 1968 San Jose GT 390 Fastback Tie Rods & Drag (Center) Link  (Read 1635 times)
Offline bullitt68
« on: December 31, 2019, 04:28:47 AM »
I found more original rusty parts today. Just looking to confirm if these are correct for my car. They look correct and the guy I got them from said that they are correct. If they look legit I will media blast them and see what condition they are in under the rust. I Just don't want to waste anytime on something that is not correct as I already have a restored set of service replacements.
« Last Edit: December 31, 2019, 04:41:07 AM by bullitt68 »
Mike
Re: 1968 San Jose GT 390 Fastback Tie Rods & Drag (Center) Link
« Reply #1 on: December 31, 2019, 09:18:08 AM »
The idler arm is not correct.
« Reply #2 on: December 31, 2019, 03:45:42 PM »
The powersteering idler arm is the weakest link in the steering system IMO. They are most typically replaced when worn out with aftermarket versions that have a different appearance. The Ford assemblyline version and or OEM (original equipment manufacturer) is very hard to find used and even harder to find NOS. You typically have to rebuild used ones. I always try to have some on the shelf. I seldom ever have NOS ones.
Offline bullitt68
« Reply #3 on: December 31, 2019, 04:18:34 PM »
Thanks I knew that which is why I didn't mention it as the guy who sold me the other parts said it was not correct. The one that came on my car was not original either. How about the Tie Rods & Drag Link. Are they correct?
Mike
« Reply #4 on: December 31, 2019, 05:48:29 PM »
I believe Jeff has an article about how to restore the tie rods.
I used his information as the basis for how I did mine.
Those tie rods look like mine. I think 68 is the same as 67 in as so far as the tied rod ends go.
To see mine, go here:
http://www.concoursmustang.com/forum/index.php?topic=16775.msg126444#msg126444
I cleaned, removed the rubber dust cap, covered the greasey bits with a large finger cot, media blasted with #30 glass ball, dremel with small brush on the caps, covered the cap with fine line tape and used gun blue gel with stainless steel wool on the main body.
For those who wonder about the gel, it contains phosphoric acid so you are doing a cold phosphate treatment.
New caps are from Scott Fuller.
« Reply #5 on: December 31, 2019, 06:31:28 PM »
Looks like the tie rods, and adjusters may be originals. After they are clean you'll know more and have a better idea of there condition. Not allot of pictures of the center links but in general they were typically never replaced since not allot of surfaces that typically wear or get damaged. As Bill mentioned that in the Restoring Natural Finishes article I use the example of tie rod ends since they have a number of different parts and in turn finishes
Offline 67350#1242
« Reply #6 on: December 31, 2019, 07:11:16 PM »
Even though the Fuller caps are more expensive they are the ones I would go with,  the cheaper Carpenter caps ($5) will disappoint as they seem to be made of cheap Chinese rubber that will disintegrate post haste,  even while just sitting in garage.
My experience....... Kurt.
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
Offline bullitt68
« Reply #7 on: December 31, 2019, 08:19:29 PM »
Thanks Bill I will check it out and get busy on the project and let you know how they turn out. They are pretty rusty, so hopefully I can save them
Mike
Offline bullitt68
« Reply #8 on: December 31, 2019, 08:44:32 PM »
Thanks Bill I will blast them and get some better photos
Mike
Offline bullitt68
« Reply #9 on: December 31, 2019, 08:45:19 PM »
Thanks Kurt Agreed. Now that I have correct Tie Rods I will be able to run the correct caps
Mike
Offline bullitt68
« Reply #10 on: January 01, 2020, 02:27:56 AM »
Hi Jeff here is a better photo of the Drag Link. What do you think could it be correct?
Mike
« Reply #11 on: January 01, 2020, 09:51:45 AM »
The drag link looks spot on to me, you should be all set there.
Offline bullitt68
« Reply #12 on: January 01, 2020, 01:21:14 PM »
Great thanks John. I am getting closer. I almost have all of my incorrect steering components replaced with correct ones.
Mike
« Reply #13 on: January 01, 2020, 05:08:59 PM »
+1 Looks good another thing off the list :)
Offline bullitt68
« Reply #14 on: January 01, 2020, 11:13:17 PM »
Thanks Jeff. Slowly but surely I am chipping away at the list. Here are the tie rods after disassembly, cleaning & media blasting. I have a couple of questions.
Since the ball joint on the tie rods do not use grease fittings, how is grease applied or are they greaseless or pre greased ball joints.
Regarding finish, would it be better to use a less correct part that looks better than a correct part that does not looks as good.
The tie rods/drag links, leafs and a few other suspension parts I picked up recently seem to be correct but quite rusty. I don't want to waste any time on parts if they are not up to snuff visually.
I need to make sure that any original parts I use are safe and mechanically sound of course.
I still need to finish them to get them to look correct, but I wanted to see how they cleaned up first before I invest anymore time into the project.
Mike
