Join us on Facebook: Search for 'ConcoursMustang' Private group!https://www.facebook.com/groups/concoursmustang/Indiana SAAC Fall Classic , French Lick, IN Oct 11-12http://www.insaac.org/SAAC National-Sanctioned Concours Event
Did you review these threads? There's some good information in there:http://www.concoursmustang.com/forum/index.php?topic=17038.msg106864#msg106864http://www.concoursmustang.com/forum/index.php?topic=19104.msg120524#msg120524
This is one of the items I would buy if I ever see ones (that are not pitted) at swap meets, etc. They are not common at all in my neck of the woods, far from the west coast. I don't see them eBay either. You'll probably need someone that was wise enough to collect them to be willing to part with a set.
A lot of these tend to be bare metal from the factory which leads in most cases to rust and pitting. Many also have joints or bushings that wear out. Some of the Ford aftermarket (upper control arms) were functional but quite different. Put all of this together and, as they say, it is what it is. Patience and/or dollars are usually part of the solution.
I just picked up these rear shackles and I am wondering If these would be good to use. Did the originals have any markings or part numbers stamped on them for identification. These look similar to original in shape and might be alright if I can get the finish right. Should they be Manganese phosphate or black paint. For some reason I though that the bolts were separate, but these have the blots pressed in to the shackles and of course are zinc plated (no bueno)
............ Should they be Manganese phosphate or black paint. For some reason I though that the bolts were separate, but these have the blots pressed in to the shackles and of course are zinc plated (no bueno)
Yes these appear to have been bright zinc plated. Might need to soak these for a long time to remove the coating rather than blasting them and adding texture but your choice. As shown in a couple of threads and in an article on natural finishes you may choose to darken the studs to reproduce the heat treated metal and this will provide a contrast (of the end of the stud) from the sides when compared to the natural look of the metal for the shackles
I will move one of the bolt/studs over to the other position so that I have the non offset shackles and then will phosphate.
Them. I guess that I could also stamp the part number in them or is that frowned upon.
Hi Jeff looks like I read this after I already media blasted the shackles and then vapour blasted them. I will move one of the bolt/studs over to the other position so that I have the non offset shackles and then will phosphate. Them. I guess that I could also stamp the part number in them or is that frowned upon. I will update the thread with the final product once I finish the project. Thanks for the help and advice as alwaysFYI these are Scott Drake shackles
I tried that and it was not possible due to the differences in the stud hole and mounting hole sizes. You will also wind up with an unusable flat plate.The only part number I've found is on the flat plate, "C6DA".Jim
Correct no engineering numbers on the shackles . I think that the C6DA was eliminated on the flat plate for 68/69 Mustang shackles.
