Author Topic: Trunk Drop/Rear Quarter Panel Drain Differences  (Read 6018 times)
« on: December 20, 2019, 09:10:06 PM »
The question came up in another thread this week but since the following covers more than just a couple of years thought it would better serve the membership to post some pictures here, in a new thread. Hope this serves to help others
65 trunk drop panel without back up lights
Blue arrow - hole and rubber plug
Red arrow - trunk drop/rear quarter panel drain location  (same location on 66 Mustangs) Rubber torn from age and use I guess
66 trunk drop (all have back up light wire loom)
Purple arrow - back up wire, hole and grommet
67-up into at least 71 production,  trunk drop example
Green arrow - trunk drop/rear quarter panel drain location
Another picture showing the attachment (upper square hole) and drain holes
Its often a surprise to owners that have had rear sheet metal repair or replacement to discover the wrong panels were used leaving the car with no drains or the wrong (for the year) drains on one or both sides.
« Last Edit: December 20, 2019, 10:34:13 PM by J_Speegle »
Re: Trunk Drop/Rear Quarter Panel Drain Differences
« Reply #1 on: December 20, 2019, 09:30:31 PM »
Any chance you can add the drain hole locations and style for each year?
« Reply #2 on: December 20, 2019, 10:33:26 PM »
Picture #1 shows the location for 64-66 and the last picture shows the location for 67-70 but guess I could do a better job and find pictures of each with the rubber "fixtures" not attached. Will see what I can do. Just grabbed a few examples that at least showed some of the details.
Offline racincast
  • may 65 FB Metuchen
« Reply #3 on: March 25, 2021, 07:19:23 AM »
Hi, Sorry for this amateur question:
On my 65 Metuchen FB passenger side 1/4 panel was replaced (terrible molding and job) and on driver side there was a patch on the rear bottom so no drain plugs on both sides.
Question: Does this car has 1/4 panels drain plugs?
Fastback GT 5T09A16XXXX
WIMBLEDON WHITE
Bright Red Interior
« Reply #4 on: March 25, 2021, 09:00:04 AM »
yes those items should be present. check the pics in the library section for unrestored cars.
« Reply #5 on: March 25, 2021, 03:21:19 PM »
Sounds like it doesn't but as mentioned it did originally
Offline racincast
« Reply #6 on: March 25, 2021, 06:05:19 PM »
Thanks, I don't know if there are best reproductions on aftermarkets 1/4 panels, but the one on my car seems to be molded on top of another one, so lot of work to fit it correctly, on driver side the same with rear bottom patch repair
WIMBLEDON WHITE
Bright Red Interior
Offline racincast
« Reply #7 on: March 25, 2021, 06:08:19 PM »
Hi
any picture without the drain rubber and measurement to place it correctly.
WIMBLEDON WHITE
Bright Red Interior
