Author Topic: Trunk drop off holes  (Read 1660 times)
Offline fmr187
« on: December 15, 2019, 04:19:01 PM »
The trunk drop off on my 65 has 3 holes in it. One is toward the rear which I think is for the wires to the back up lights. My question is the 2 holes toward the front. One is round and then a square hole above it. What are these 2 holes for and what goes in them?
« Last Edit: December 20, 2019, 09:11:31 PM by J_Speegle »
65 Convertible born in Dearborn on Feb 10
Re: trunk drop off holes
« Reply #1 on: December 15, 2019, 05:05:29 PM »
The 67-8 style turn-downs have been used.
« Reply #2 on: December 15, 2019, 06:42:05 PM »
 If on a 65/66 then a 67-70 style drop off has been used by someone during a repair.
Offline PraireBronze
« Reply #3 on: December 15, 2019, 08:57:24 PM »
Are there correct full trunk floors available for '65?  Mine were replaced back in the day with incorrect ones.
- Tim -
1965 Prairie Bronze 2+2 (under construction)
Build Oct '64 San Jose
289 4V Automatic Transmission (A-code clone :P )
Black Std Interior
AC, PS, Style Steels, 1" Drop, Konis
Aluminized 2 1/4 Exhaust, Tri-Ys
« Reply #4 on: December 15, 2019, 09:44:58 PM »
Believe there are - even seen them installed on 69  :o
Can't recommend a provided since I've never bought any
Offline fmr187
« Reply #5 on: December 16, 2019, 10:59:29 AM »
According to the 4 different Mustang supply catalogs that I have this part is listed as 64-70. Nothing specific for year 65. So what would be correct for 65? Which holes belong and which don't? What is needed to correct this? Anyone have  a picture?
« Reply #6 on: December 16, 2019, 12:44:49 PM »
Would be best for someone to post some pics of turn-downs from a Feb Dearborn 65 car.
Be very cautious when using parts vendor catalogs in determining what is right or wrong.  Sometimes, as in this case, it's a 'fits' description rather than period correct.
Modifying the ones installed might be possible.  If your car has backup lights, then it wouldn't have the hole to the rear.  If it did, then the hole would be smaller for the smaller wiring rubber grommets used in 65-66.
The square hole above the front larger hole would have to be filled.
Offline rocket289k
« Reply #7 on: December 16, 2019, 01:45:02 PM »
Hi Charles,
Are you aware of any differences between the plants or intra-model-year changes for the trunk drop offs in 65?  If not I have a nice clear picture of a factory trunk drop-off of a late July 1965 Metuchen build (no backup lamps).
Ron
« Reply #8 on: December 16, 2019, 02:28:17 PM »
Hi Charles,
Ron
I'm not aware, but best to focus on Dearborn in case there are differences.
Offline rocket289k
« Reply #9 on: December 16, 2019, 03:00:11 PM »
Completely agree - best not to confuse things in that case.
Ron
Offline fmr187
« Reply #10 on: December 18, 2019, 07:42:28 PM »
From what all you guys are saying the 2 holes on the right should no be there on a 65. So I should fill them in to make this more period correct? If these holes were used for 67-68 what exactly went thru them? just curious.
« Last Edit: December 18, 2019, 08:33:58 PM by Bob Gaines »
« Reply #11 on: December 18, 2019, 08:05:06 PM »
Back up light wiring.
« Reply #12 on: December 18, 2019, 08:34:11 PM »
The forward holes (one small square and a larger round) were for the rubber moisture weep valve used on 67-70 Mustang. The 65/66 had a different shaped long and narrow rubber valve mounted on the bottom side of the drop off area.
« Reply #13 on: December 20, 2019, 08:56:14 PM »
Posted this in the General Body section of the site to illustrate the differences referred to in this thread. Hope this helps
http://www.concoursmustang.com/forum/index.php?topic=21575.new#new
« Last Edit: December 20, 2019, 09:11:06 PM by J_Speegle »
Offline fmr187
Re: Trunk drop off holes
« Reply #14 on: December 22, 2019, 01:23:44 PM »
Thanks Jeff the pictures and info are very helpful. I guess no I have to fill some holes. Darn it.
