Author Topic: 1969 Cyclone rear quarter glass removal tips  (Read 4755 times)
Offline kwemj 67
« on: December 14, 2019, 09:15:59 PM »
Hi guys,
 Working on my uncles 1969 Mercury Cyclone with power windows and was wondering what tricks there are to removing the quarter glass and regulator.  I built a jumper wire and battery to manipulate the window motor. But was wondering what is easiest way to remove everything so car can get blasted.  Any help would be appreciated.  Thanks.
7R03S157303 GTA
Offline 1969 Cale II
Re: 1969 Cyclone rear quarter glass removal tips
« Reply #1 on: December 29, 2019, 05:52:36 PM »
First big part is remove all bolts and stuff and drop glass into the quarter panel. Then you can remove the chrome trim on the outside and then pull out the glass. You can not remove the glass with that banana piece in. Also, put glass back in hole before you put the trim on. PM me with anymore questions, have worked on a few of these cars. Chris
Offline kwemj 67
« Reply #2 on: April 06, 2020, 12:27:34 AM »
Thanks for the reply Chris. Did get them out and yes dropped them after unbolting everything and pulling all the chrome trim and then turned the glass almost 180 degrees and came out upwards toward drip rail, pretty tight fit for a big quarter window. Thanks again
7R03S157303 GTA
