Author Topic: 1968 San Jose GT 390 Fastback Front Brake system  (Read 840 times)
Offline bullitt68
« on: December 13, 2019, 10:58:55 PM »
Just curious if the following parts are original for my car.  I want to be sure what I am working with before I restore them and prep the assemblies for installation.
1. Front Brake Callipers (Painted Semi Gloss Black or Natural Finish)
2. Front Calliper Pistons
3. Front Calliper Piston Seals (Will replace, just checking if they are original based on part number)
« Last Edit: December 13, 2019, 11:04:17 PM by bullitt68 »
Mike
Re: 1968 San Jose GT 390 Fastback Front Brake system
« Reply #1 on: December 13, 2019, 11:31:15 PM »
The calipers were bare cast iron from the factory.
Offline preaction
« Reply #2 on: December 13, 2019, 11:33:50 PM »
 All Kelsey Hays parts.
« Last Edit: December 13, 2019, 11:37:06 PM by preaction »
Offline bullitt68
« Reply #3 on: December 13, 2019, 11:42:51 PM »
Thats what I thought. I did read that some models did get black paint just like the rear brake drums. Mainly on 1969 Mach 1's with Magnum 500 wheels I believe. I always like to double check and not assume.
Thanks Bob
Mike
Offline bullitt68
« Reply #4 on: December 13, 2019, 11:43:15 PM »
So all original/correct parts for my car?
Mike
« Reply #5 on: December 13, 2019, 11:56:35 PM »
Correct parts but not original to your car IMO .
Offline bullitt68
« Reply #6 on: December 13, 2019, 11:58:49 PM »
Is there a reason you say that. Just trying to piece the puzzle together and getting close. This is they final piece to fill in
Mike
« Reply #7 on: December 14, 2019, 12:01:09 AM »
The metal stamped date code which ever way you look at it is after the build date of your car based on info you post about your car.
« Reply #8 on: December 14, 2019, 12:06:25 AM »
Your style of calipers are commonly , easily, and cheaply replaced during brake jobs. You go to the auto parts store and get a rebuilt set and turn in your set that you took off as a core.
Offline bullitt68
« Reply #9 on: December 14, 2019, 12:21:52 AM »
Ok got it. So apart from the date code the callipers are correct
Mike
« Reply #10 on: December 14, 2019, 12:31:44 AM »
Calipers are correct apart from the date code IMO.
Offline bullitt68
« Reply #11 on: December 14, 2019, 12:34:44 AM »
Great thanks
Mike
