Author Topic: Engine ID stickers - anyone have an original with plant code "D"?  (Read 4337 times)
I am starting this thread to see if anyone has an original one to use as an example so that reproductions can be made properly. Currently the vendors all sell a version of this sticker that has an "L" for the plant code, ie Lima Ohio. So far as I have been able to determine all 428 CJ engine assemblies were built at Dearborn Engine Plant, which would mean the ID sticker should have a "D".
I think if the sticker was on a 289, 302, or even a 390 from 1968 - 70 it would have a similar "D" if the engine was assembled at DEP.
Here's the reproduction 407J sticker:
Re: Engine ID stickers - anyone have an original with plant code "D"?
« Reply #1 on: December 04, 2019, 04:42:49 PM »
No 289 or 302s from Dearborn Engine Plant (DEP). From the late 50’s through late 70’s they only made the FE engines.  If I recall correctly that was an exclusive thing.  My grandfather was a manager there from 41-44 in the strategic air command group making Pratt & Whitney engines.
« Reply #2 on: December 04, 2019, 07:12:22 PM »
Much appreciated. Wish I could see what a sticker looks like from any DEP engine of any displacement.
Offline warwick
« Reply #3 on: December 06, 2019, 08:40:12 AM »
The original engine tag was on my car and in around 1997 it was ready to fall off so I put it in a bag-I have it somewhere. As I recall the engine code you could still see but not much else.
The original metal engine tags do not id the plant on either my Windsor sm block or FE.
« Reply #4 on: December 06, 2019, 09:51:45 AM »
Would love to see it if you still have it.
Offline cobrajet_carl
« Reply #5 on: December 06, 2019, 11:44:36 AM »
I have an original metal tag on my 70 351C that has a C on the first line. None of my 428CJs have a plant code on the metal tag. I wonder what Marti would do on a repo tag for an FE.
Marcus's 428 detailing guide shows several paper tags with the D
« Last Edit: December 06, 2019, 12:01:00 PM by cobrajet_carl »
Carl
70 and 71 Dearborn mach Is
« Reply #6 on: December 06, 2019, 06:30:21 PM »
I have both original engine tags and repro engine tags from 427 and 428CJ engines. None have a plant code.
I made this today, maybe if I get the edges cut like the ones in Marcus' pictures it will look right?
Offline Mike_B_SVT
« Reply #7 on: December 07, 2019, 10:09:17 PM »
That's cool!  I'm going to need a 424 A for my '70 SCJ.
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
« Reply #8 on: December 09, 2019, 04:02:38 PM »
Some fine pinking shears and it will look great!
Carl
« Reply #9 on: December 09, 2019, 04:36:22 PM »
My thoughts exactly. Will try Michaels and Hobby Lobby to see what they have.
« Reply #10 on: December 11, 2019, 11:55:19 PM »
I assume the timing on the paper decal should match the initial timing spec on the emissions sticker for any engine.
Carl
« Reply #11 on: December 12, 2019, 10:34:16 AM »
It certainly does!
« Reply #12 on: December 12, 2019, 01:45:47 PM »
The teethed edges of engine tag was from a roll torn off like a tape holder with the metal teeth blade so just find an old tape dispenser. I still haven't found my original cj take off tag and ECS may have it yet as he made tags and decals from my originals. I remember discussing the id #s on the engine tags years ago when we were making these but don't remember what we decided on this and dave walden owner of ECS sadly passed away last july .
« Reply #13 on: December 12, 2019, 01:55:11 PM »
If the label is wide it's hard to find a tape dispenser that wide.
Instead raid the kitchen and find a rolled aluminum foil dispenser.
Those teeth look and work pretty good and are over 12" long. You could just steal the metal strip and mount (staple) it on a piece of plywood for garage use.
If you want a hand held version look for scrapbook pinking scissors.
The scrapbookers love weird edges.
« Reply #14 on: December 15, 2019, 09:00:56 PM »
I've used a package tape dispenser most of the time as shown in the thread about reproducing these stickers here on the site. Before that saw blades.
