Author Topic: 1970 exhaust hangers  (Read 6856 times)
Offline joe747
« on: December 08, 2010, 05:54:55 PM »
looking to buy orginal  brack for my daul exh. mustang but not sure what to buy , everyone on e hay says that they took them of a 69-70 mustang but they all look different
Offline joe747
Re: 1970 exhaust hangers
« Reply #1 on: December 10, 2010, 05:36:18 PM »
anyone know were i can get info on this or another web site i can check it out
thanks
Offline Anghelrestorations
    • Anghel Restorations
« Reply #2 on: December 10, 2010, 07:30:10 PM »
I have original exhaust hangers - let me know exactly what you need to know here.  What motor do you have and exhaust system are you using and maybe I can post some pictures.
Marcus Anghel
www.anghelrestorations.com
Offline joe747
« Reply #3 on: December 11, 2010, 09:31:00 AM »
1970 mach 1 351 4v dual exh
« Reply #4 on: December 16, 2010, 07:32:32 PM »
Here is photos of what original exhaust hangers for the mufflers would look like.  There is FoMoCo stampings and Z and W stamped on the brackets for what I believe was used to distinguish left and right side:
And this is what the current reproduction I have looks like compared side to side:
Marcus Anghel
Offline joe747
« Reply #5 on: December 16, 2010, 09:01:22 PM »
great pics . i must have ones from a 68 .the top brk are different
« Reply #6 on: December 17, 2010, 04:52:31 PM »
I stand corrected here...the Z and W stamping on these brackets most likely is for Mustang versus Cougar applications.  You can also see the length of the rubber is different between the left and right side.  But other than that, this is what original hangers would look like.  Just need a matched set.
Marcus Anghel
Offline joe747
« Reply #7 on: December 17, 2010, 08:26:07 PM »
do you mean one is from a mustang and one from a cougar
Offline shelbyboss302
« Reply #8 on: December 18, 2010, 02:54:21 PM »
Factory single exhaust muffler hanger are different than the factory duel exhaust hangers and have different part numbers.
Offline joe747
« Reply #9 on: December 18, 2010, 06:26:51 PM »
my top brks are diffeent from  the the ones pic here . i will try and post some pics . i do have a left and a right which are diff from each other
« Reply #10 on: December 20, 2010, 01:49:37 PM »
Best would be to post some pics of exactly what you have so we can see...we probably should have done that first.  And yes, the single exhaust brackets are different...but the question here was on the dual exhaust brackets.
Marcus Anghel
« Reply #11 on: December 20, 2010, 08:37:51 PM »
I posted 2 NOS 1970 Mustang exhaust brackets for your reference. One bracket shown is off dual exhaust LH as previously posted and the other is off single exhaust RH. They look the same at a quick glance. The Z designates right side and the W is for the left side. Cougars have different part numbers but still have the Z and the W markings. Hope this helps....Shelby
Dual Exhaust LH
Single Exhaust RH
Offline PerkinsRestoration
« Reply #12 on: December 20, 2010, 10:08:33 PM »
The 351C 2V also uses the D0ZZ-5260-A front hanger & all 70 Mustang use the same C8ZZ 5260-B RH rear hanger including 6 CYL.
Offline joe747
« Reply #13 on: December 20, 2010, 10:26:35 PM »
here is a pic of the bracket i have one has a part number c8za the other has a w
« Reply #14 on: December 21, 2010, 02:13:13 PM »
Shelby - From the pictures you posted, the hanger with the paper tag reads as a C9ZZ-5260-B which is for a 2 barrel single exhaust 302 Mustang.  What is the other hanger in the pictures?  Do you have the part number for this....I see a partial part number on one of the boxes, but dont know if the boxes go with the hangers.
Marcus Anghel
