Author Topic: 1965 Engine Mount Assembly and Hardware Finishes?  (Read 855 times)
Offline 66RavenGTCoupeAgain
« on: November 23, 2019, 06:03:55 PM »
Hi guys,
I've done a few searches on here but can't find the correct finishes for my 1965 engine mounts assemblies and hardware. I believe the bolts should be phosphate and oil and the nuts zinc coated but I really want to confirm this as well as the cast brackets, middle brackets and rubber mount brackets please. Any help and or pictures would be most appreciated.
Dan.
66 Metuchen NJ  GT Coupe
6T07A1612## Dec 65 Build
5R08C1496## Oct 64 Build
Re: 1965 Engine Mount Assembly and Hardware Finishes?
« Reply #1 on: November 23, 2019, 06:49:35 PM »
First would like to confirm that your asking about non-Hipo V8  (not 6 cylinder) motor mount details.
« Reply #2 on: November 24, 2019, 06:20:56 PM »
Hi Jeff,
This is for a 289 C Code. Sept 64 build  at SJ.
Thanks.
« Reply #3 on: November 24, 2019, 07:39:23 PM »
Did you look in the Library section of this forum under Mustang Hardware Spreadsheet 64-66. There are two files, one by part number, the other by application. Also, a set of Mustang Assembly Manuals for your year car help a lot.
« Reply #4 on: December 04, 2019, 04:18:50 PM »
Oh ok. Will check it out. Thank you.
