Author Topic: 1970 Instrument and Clock Cluster Wood Grain Cleaning  (Read 1219 times)
Offline 1970 Snake
« on: November 21, 2019, 07:53:00 PM »
I would like to properly clean the walnut woodgrain bezels on my instrument and clock dash housings. Looking for advise on how to do a good cleaning without damaging the wood grain finish.
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Re: 1970 Instrument and Clock Cluster Wood Grain Cleaning
« Reply #1 on: November 21, 2019, 08:18:10 PM »
I have always used lemon pledge.
« Reply #2 on: November 21, 2019, 08:36:17 PM »
Since its a vinyl multi layer decal the more mild a cleaner that will not affect the adhesives the better. Agree Lemon Pledge the older aerosol if its still available sprayed on a new/clean micro fiber towel would work well. Remember the less you rub the less likely your going to damage anything including the surrounding painted or "chrome" surfaces. The Lemon Pledge will attract dust but nothings perfect it seems
Offline 1970 Snake
« Reply #3 on: November 22, 2019, 12:23:07 AM »
Much appreciated, thanks guys, I will try the lemon pledge.
Offline 1970 Snake
« Reply #4 on: April 05, 2020, 05:29:23 PM »
I know this thread has not been commented on for over three months but I just though I would advise on what I finally did to resolve my issue. So I tried the lemon pledge and it did not remove the water marks on my original woodgrain bezels, so I had an old 1969 damaged bezel and did a test on it with Autosol metal polish liquid, applied it with a micro-fiber cloth and polished it off with a clean cloth, it worked amazingly quickly and cleanly not damaging any of the printed woodgrain. I am completely restoring my instrument speedo/tach and clock/map light clusters and had the woodgrain bezels removed to do the bezel cleaning although I am sure this method can be use on installed units.
« Reply #5 on: April 05, 2020, 05:45:14 PM »
Thanks for the follow up. It's always helpful if we post what worked and didn't work
Again thanks for posting
Offline 1970 Snake
« Reply #6 on: April 05, 2020, 06:06:07 PM »
Thanks Jeff, this is a great forum to learn and to pass on when you can, glad I could help.
