Author Topic: 1965 200ci Air Cleaner & Valve Cover color  (Read 603 times)
Offline gimmea250swb
« on: November 21, 2019, 03:18:35 PM »
I need to paint my son's air cleaner.  I found the link below that suggests the closest paint color for the parts; however, there's nothing about a blue air cleaner and valve cover.  My son's are blue and I see several photos online with blue as the color.
Should they be blue?  If so, what's the closest match?
http://www.mustangandfords.com/how-to/paint-body/mump-0308-select-correct-vintage-mustang-engine-paint
'66 Shelby Feb build
'65 FB 5T09T164019
Re: 1965 200ci Air Cleaner & Valve Cover color
« Reply #1 on: November 21, 2019, 04:38:13 PM »
Not really up to speed on all things 6 cylinder but it might help to know the cars VIN or when it may have been built.
Have a fair number of original car pictures just don't want to offer any help without knowing we're focusing in on the same thing ;)
Though I think I know the answer want to be sure.
BTW there is a set of pictures (valve cover and air clearer are just visible in one) in the unrestored picture threads. Guess I should find time to add some more examples.
I won't have a suggestion about the closest current paints since I've not done one but hopefully another member that has applied the red recently will
« Last Edit: November 21, 2019, 04:43:55 PM by J_Speegle »
« Reply #2 on: November 21, 2019, 04:42:32 PM »
Hi Jeff,
Thanks for your help!  The VIN is 5T09T164019.  I hope this helps.
'65 FB 5T09T164019
« Reply #3 on: November 21, 2019, 04:50:20 PM »
Within a few thousand numbers is as close as I can get this time - 5T16182x
Color appears to be a bit bright from camera settings and the lighting
Maybe a better representation - same engine and color - different cars but all built at the same engine plant
