Author Topic: Rally Pac Gauges  (Read 2568 times)
Offline Norcal87
Rally Pac Gauges
« on: November 12, 2019, 07:59:51 PM »
Here’s some pics of my Gauges
Re: Rally Pac Gauges
« Reply #1 on: November 13, 2019, 03:29:09 PM »
Did you have a question about them or some other concern?
Offline Norcal87
« Reply #2 on: November 14, 2019, 06:11:59 PM »
The owner said there factory anyway to tell if there aftermarket ?
« Reply #3 on: November 14, 2019, 06:16:36 PM »
look factory to me.
« Reply #4 on: November 14, 2019, 07:28:30 PM »
That is a 65 type Rally Pac installed on a 66 Mustang. The Ford tach was wired under the dash, "inline" with the resistance wire. (It goes to the coil terminal marked BATT.) To verify the type of tach, you need to to look at the coil. It should have three wires, the large diameter "spark" to the distributor top, one to the distributor (marked DIST) side and BATT. If that's all of the wires there are, your Rally Pac is probably an original. An aftermarket tach in a Rally Pac adds that other wire and is not wired "inline".
Offline Norcal87
« Reply #5 on: November 14, 2019, 10:52:00 PM »
Here’s some pics of it off the car
« Reply #6 on: November 15, 2019, 12:20:14 AM »
Was there an extra wire on the coil that went thru the firewall to the tach?
Offline Norcal87
« Reply #7 on: November 15, 2019, 01:29:31 AM »
Yes
« Reply #8 on: November 15, 2019, 04:39:16 PM »
A rally pack (style) could have been what the dealer had on the shelf and sold to an early owner rather than ordering (moving old stock) a newer version. Of course plenty of people may interject to you at shows that you have the "wrong" one  ::)
« Reply #9 on: November 15, 2019, 07:09:26 PM »
Yes
In that case, it is probably a reproduction. Remove the clock cover and see if there is a Ford part number.
Offline rocket289k
« Reply #10 on: November 15, 2019, 08:26:56 PM »
The easiest way to identify if the Rally Pac is an OEM (vs. a repro) is to take the tach out of the camera case black housing.  Here is a pic of the back of a 1965 style rally pac tach.  It has a total of 3 wires (two for the tach (1 red and 1 black) and one for the light bulb (blue with a red stripe).  If there are more than 2 wires for the tach is it either a repro or it has been rebuilt/modified.  In addition the back of the housing will have a faint ink stamp.  See attached photo.
Regards,
Ron
Offline Norcal87
« Reply #11 on: November 15, 2019, 10:57:08 PM »
It looks that it was modified long time ago. All I know on the cars history it was purchased used in 1970 at a ford dealer.
Offline Norcal87
« Reply #12 on: November 16, 2019, 06:56:05 PM »
Pics of tach gauge
Offline NEFaurora
« Reply #13 on: December 11, 2019, 01:57:55 AM »
Originals will have "Thomas Faria" Corp.  Ink Stamped on the back as pictured above...
:o)
Tony K.
MCA#70001
